strange performance of execFlowFunctionObjects |
February 28, 2017, 10:57 |
Rep Power: 10 |
I recently find that execFlowFunctionObjects outputs different results with the solver output. Take the DTCHull case as an example, when I use interFoam and output the log file. The forces output in the last timestep is:
===================================== forces forces output: sum of forces: pressure : (-2.87174 1621.49 3915.17) viscous : (-12.8331 -0.209267 -0.278943) porous : (0 0 0) sum of moments: pressure : (-521.019 27.7322 430.802) viscous : (0.023115 3.04292 -3.95596) porous : (0 0 0) ===================================== and when I recalculate the force using execFlowFunctionObjects -latestTime, it outputs: ===================================== forces forces output: sum of forces: pressure : (-2.87174 1621.49 3915.17) viscous : (-68.8092 -12.4143 5.80855) porous : (0 0 0) sum of moments: pressure : (-829.102 -3807.88 2019.12) viscous : (3.00731 -44.1551 -66.8254) porous : (0 0 0) ===================================== Only the pressure forces are the same. Does anybody know the reason? Thanks |
March 25, 2017, 07:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: execFlowFunctionObjects was deprecated precisely because it didn't support all transport models, such as multiphase.
You need to either run it with the solver in older versions, or create a modified version of execFlowFunctionObjects or use OpenFOAM 4.0 and newer to use the solver itself, e.g. interFoam -postProcess. More details in the release notes, look for "function objects": https://openfoam.org/release/4-0/
DPM strange performance decrease with many injections | einandr | Fluent Multiphase | 7 | August 28, 2023 19:27 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 14:40 |
parallel performance on BX900 | uzawa | OpenFOAM Installation | 3 | September 5, 2011 15:52 |
Linux kernel performance enhancement | ConnClark | OpenFOAM | 0 | January 17, 2011 18:18 |
ANSYS CFX 10.0 Parallel Performance for Windows XP | Saturn | CFX | 4 | August 13, 2006 12:27 |
