Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Tracking of location of zero wallShearStress point along a wall/line.
Old   March 27, 2017, 16:17
Default Tracking of location of zero wallShearStress point along a wall/line.
Saurav Kumar
srv537 is on a distinguished road
I am trying to simulate flow in backward facing step with oscillating flow so the reattachment point will oscillate along a point (as mentioned in attachment ), I want to track this reattachment point ( grad(U) / wallShearStress = 0 ) with time, I don't know how to do this.
I am using OpenFOAM 4.
I think I need to do something similar to
https://cfd.direct/openfoam/user-gui...rocessing-cli/
minMaxComponents: Writes out the minimum and maximum values, by component for non-scalar fields, and the locations where they occur.
minMaxMagnitude: Writes out the minimum and maximum values, by magnitude for non-scalar fields, and the locations where they occur.
I don't know how to use these function, please help me.
Kind Regards
Saurav
File Type: png Screenshot from 2017-03-28 01-31-03.png (38.4 KB, 18 views)
srv537 is offline   Reply With Quote
Old   March 28, 2017, 00:49
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may use
wallShearStress -latestTime
which gives you the surface stress.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 28, 2017, 17:44
Saurav Kumar
Originally Posted by piu58 View Post
You may use
Simulation will be unsteady so will it give wallShearStress at every time step, do i need to define it in controlDict file ?
how can i define this function ?
Regards,
saurav
Old   March 29, 2017, 00:44
piu58's Avatar
Uwe Pilz
Leave the -latestTime and you get it in every time folder.
Uwe Pilz
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Probe point by his ID (not his location) Tscar OpenFOAM Post-Processing 4 August 6, 2018 10:38
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
