Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Heat flux report
Old   March 31, 2017, 10:56
Default Heat flux report
Tet
thsr1sf is on a distinguished road
Hello all,
I'm trying to report wall heat flux in openfoam but I can't bacause I use OF-4.x and incompressible scheme.
Does anyone know how to report it?
thsr1sf is offline   Reply With Quote
Old   April 13, 2017, 12:19
Default Wall heatflux for incompressible flow.
Himanshu Sharma
himanshu28 is on a distinguished road
You can clone the repository from following github link below. I also got it from somewhere in the forum only.
https://github.com/Himscipy/wallHeatFluxIncompressible
Regards
himanshu28 is offline   Reply With Quote
Old   April 25, 2017, 08:30
Retired Super Moderator
Bruno Santos
Greetings to all!
@himanshu28: Please also document in your repository for which OpenFOAM version your code works with!
And I guess you didn't find that there was already a repository for a utility with the same name, being discussed in another thread: https://github.com/wyldckat/wallHeatFluxIncompressible
There is also a wiki page for this utility: https://openfoamwiki.net/index.php/C...Incompressible
@thsr1sf: If you are using OpenFOAM 4.x, you can use the function object "wallHeatFlux". This is because (quoting myself from here):
the Boussinesq implementation is now part of the compressible heat transfer solvers, therefore no longer depending on explicit solvers dedicated to the Boussinesq implementation.
This means that you can use OpenFOAM's own wallHeatFlux utility.
Best regards,
Bruno
Old   April 25, 2017, 11:54
Himanshu Sharma
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hi Bruno,
Thanks for the update and suggestion.
I said in my post that "I got it from somewhere in the forum" , I didn't remembered the post though.
Regards
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Forced convective heat transfere with fixed heat flux? BenFranklinIII OpenFOAM Running, Solving & CFD 0 July 30, 2015 05:31
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Heat Flux , Convective + Radiant Heat flux Mandeep CFX 3 October 25, 2012 16:57
