August 18, 2017, 13:19 |
Files coming out as empty
Max Spencer
Hi there
I have a set up simulation examining the effect of airflow on a pool of volatile gas. I have run this simulation in parallel on 12 processors. After using reconstructPar, after a certain timestep all the values of the fields (air, U, T phi) all go to zero, I know this cannot be right as in their respective processor folders these fields still exist at that timestep. Is there any particular reason for this? |
August 18, 2017, 16:33 |
One of the reasons could be disk space (or disk quota). |
paraview, phi |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
[snappyHexMesh] sHM quality of multi-region | aminem | OpenFOAM Meshing & Mesh Conversion | 0 | April 16, 2015 11:38 |
UDF help for Rapid compression machine ECM. | sanjeetlimbu | Fluent UDF and Scheme Programming | 0 | March 17, 2015 22:45 |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
