Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Reynolds Stresses Tensor from OpenFoam
Old   August 29, 2017, 09:04
Default Reynolds Stresses Tensor from OpenFoam
Irstea is on a distinguished road
Hello everybody,
I'm post Processing some calculations made with OpenFoam in order to confront them against some experimental data. These simulations are diphasic RANS with RSM turbulence Model.
I'm struggling right know with the Reynolds Stresses tensor compute by OpenFaom.
To be sure that I'll compare the same thing between xp and sim, I exported U and R fields from Openfoam and check that I manage to find OpenFoam results from U.
From U, I recalculated the Reynolds Stresses tensor from the basic :
Rij = Mean(u'iu'j)
That is just to calculate the covariance Matrix of U (Cov(U)).
Unfortunetly, when I compare the post process values of U with the R exported from OpenFoam, it does not match.
I've got R(openFoam)=\sqrt{R(postprocess)}.
It means for the diagonal, it seems that Openfoam calculates the standard deviation of U instead of the variance U.
However, when you check the units of R(openfoam), the R file tells you that is in mē/sē.
I exported results calculated directly from the simulation and those made by the post-process function 'R', and I've got the same issue.
Is it just that definition of R in openfoam is not quite the same than in litterature? But why is it still in mē/sē?
Irstea is offline   Reply With Quote
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 10:19
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
what are reynolds stresses UnderGroundMan CFX 2 November 10, 2008 12:31
What Form of Reynolds Stresses Data Is Used? S. Bottenheim Siemens 1 February 16, 2005 07:25
