how to probe a single velocity component using probeLocations |
August 15, 2014, 08:05 |
Davide Lasagna
Rep Power: 11 |
I am using with success the utility probeLocations to probe the pressure field at selected points. Probing the velocity field also works in general, but I need only one of the velocity components. I could parse the generated file for post processing, but it would be more simple if i only get one velocity component only, as the resulting file would be simpler. Is this possible? Thanks, Davide |
August 19, 2014, 11:53 |
Ontario
hi
i am trying to do the same job.would you please tell me how you did that? i want to calculate the pressure on some points on my column but i do not know the file which should be added in contdic thanks alot |
January 29, 2018, 01:49 |
Kadu
Rep Power: 10 |
You can write your own solver by adding the fields . I did it for me.
To create fields (createFields.H): Info<< "Reading field Uxvel\n" <<endl; volScalarField Uxvel ( IOobject ( "Uxvel", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field Uyvel\n" <<endl; volScalarField Uyvel ( IOobject ( "Uyvel", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field Uzvel\n" <<endl; volScalarField Uzvel ( IOobject ( "Uzvel", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); For solver (solver is renamed - pimpleFoamComponentsCalc.C)- Uxvel = U.component(0); Uyvel = U.component(1); Uzvel = U.component(2); |
Axisymmetric Case 3rd Velocity Component | Mentalo | OpenFOAM Running, Solving & CFD | 2 | June 8, 2014 12:45 |
Suspected division by zero on velocity reported by point probe | dahicke | STAR-CCM+ | 1 | July 4, 2013 02:16 |
Stn frame and radial velocity component in NREL | mohammad | CFX | 1 | October 25, 2011 10:13 |
sampling a strain-rate tensor single component | vkrastev | OpenFOAM Post-Processing | 0 | March 2, 2010 07:21 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
