How to display agglomerated surfaces in paraView |
November 8, 2022, 22:33 |
mo
Rep Power: 3 |
Hi all, I am looking for a way to display the agglomerated faces in paraview.
I am doing a radiation calculation using the viewFactor model and would like to see the faces and their IDs in paraView after agglomeration by faceAgglomerate. Also, is it possible to indicate the temperature at the agglomerated surface? I would like to know just one or the other. Best Regards. |
November 9, 2022, 08:40 |
Yann
Rep Power: 26 |
In the viewFactorsDict file, there is a switch to write face agglomeration: Code:
writeFacesAgglomeration true; Regards, Yann |
November 9, 2022, 21:43 |
mo
Rep Power: 3 |
Hi,Yann.
Thank you for reply. I turned on the Face agglomeration switch and checked faceAgglomeration in the Paraview variable list, but in the Mapped Variable pull-down (where it says Solid Color) faceAgglomeration does not appear. For time, I have unchecked skip 0 and selected time 0. Do you know anything about this problem? |
November 10, 2022, 03:19 |
Yann
Rep Power: 26 |
As long as you unticked "Skip zero time" it should show up in the variable list.
Do you run your case in parallel? If yes make sure to select the proper Case Type (Decomposed Case) |
November 10, 2022, 08:35 |
mo
Rep Power: 3 |
Thanks for your reply.
I have Skip 0 time unchecked, but it does not appear in the list... I am not concerned about that problem because we are not running parallel calculations. We are not concerned about that problem because we are not running parallel calculations. |
November 10, 2022, 08:50 |
Yann
Rep Power: 26 |
If you have a look into the 0 directory, do you see a file named faceAgglomeration?
November 10, 2022, 09:16 |
mo
Rep Power: 3 |
The file faceAgglomeration can be found in the 0 directory. I can select faceAgglomeration in paraView, but it does not appear in the pulldown.
November 10, 2022, 10:34 |
Yann
Rep Power: 26 |
OK great. In ParaView, what entities are you selecting in the "Mesh Regions" list before loading the case ?
Try to untick everything and select only the patched you want to visualize. |
November 11, 2022, 00:16 |
#9 |
mo
Rep Power: 3 |
Sorry for the late reply.
I was able to get the faceAgglomeration to show up in the Mesh Parts settings! Thank you so much for all your help and guidance! |
[OpenFOAM] Paraview does not display \<name\>:alpha1 field | blebon | ParaView | 1 | September 10, 2020 08:56 |
[OpenFOAM] paraview display issue | Raymond.Leoi | ParaView | 0 | February 6, 2018 08:25 |
[OpenFOAM] Paraview does not display results | vasava | ParaView | 1 | February 22, 2016 04:52 |
[OpenFOAM] How to display element or node number in paraview 3.12.0? | shuoxue | ParaView | 1 | May 26, 2013 04:01 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
