fvOptions SemiImplicitSource - scalarSemiImplicitSourceCoeffs |
March 3, 2019, 18:30 |
Rep Power: 10 |
Hi all,
I'm still new to OpenFOAM and I'm just learning to find my way by digging through the user guide, the tutorials, CFD Online and google. I want to run the scalarTransport function 'attached' to a pimpleFoam run (OpenFOAM-v1812). I want to 'simulate' a constant scalar source from a predefined source area (in 1/s per m2 of the source area) of one of my patches. After some hours spent, I'm rather confused and need help/reassurance. I see that there are quite a few tutorials using the function scalarSemiImplicitSource, however I can only find the file SemiImplicitSource.H? Further, the documentation I found so far is rather sparse. So far I prepared a scalarTransport function containing the following fvOptions, more or less copied from one of the tutorials: Code:
... fvOptions { S-01 { type scalarExplicitSetValue; active true; scalarSemiImplicitSourceCoeffs { selectionMode cellZone; cellZone SourceArea; volumeMode absolute; // specific injectionRateSuSp { Tracer (1 0); } } } }; So, if I want to simulate a source area of 1 unit/m2/s I just have to define all cells adjacent to the source area and I'm fine with the above settings? Or how could I define my source area? |
March 5, 2019, 03:57 |
Rep Power: 10 |
After thinking more about it, I guess, IF I have a regular grid adjacent to my source area, I can define my InjectionRate Su as 1/SourceArea, but as soon as I have irregular face areas 'connecting' to my source, this does no longer hold. But this is just my guessing.
If my above guessing was true, would it be possible to set Su to 0 and define an Sp term of the source to depend on the face area through which my tracer is injected (i.e. the face that 'connects' to my source area)? |
March 5, 2019, 13:13 |
Arsenis Chatzimichailidis
Rep Power: 11 |
Hi Chris!
I am not really sure about the part with the "1 unit/m2/s", I'd rather think of it as unit/m3/s. (except the case you run 2D simulation, so I don't know!) I think that the "absolute" option is best most of the times, as you submit the emission rate inside the computational domain. You DON'T REALLY NEED this part, BUT: To be absolutely sure about the emitted value, you can run the simulation with cyclic boundaries (a fully-closed domain). In the case of "open" boundaries, run it for 1 second or 2, if you are positive that the emitted values will not arrive at the exit boundary and be purged outside of the domain. Then, you could take an integral of the emitted value all over the domain in paraview. The result should be the (emission rate)*(seconds) with a pretty good accuracy. |
March 5, 2019, 21:05 |
Rep Power: 10 |
Hi Arsensis,
Thank you for your answer! I'm running a 3D case, where I want to simulate a diffusive source of a tracer emitted from a source area (on a wall patch, e.g. a certain area on the bottom/ground of the atmosphere) with a given total, constant flux from this area (say 1 per sec or equivalent, 1/A per sec per m2, where A stands for the total area in m2 of the source). My idea was that if my cells adjacent to the source area have a rather small extension normal to the wall, I can approximate my diffusive source (acting like a constant flux BC for the scalar (Tracer)) by adding a source term to all these cells adjacent to the source area. However, I'm not sure how I should define this source term. E.g. if I choose the option 'absolute' with injection rate 1 (1/s) as in the above example, do I get 1 unit per each cell? Or 1 unit per CellZone, i.e. evenly distributed across all CellZone cells? Are there better ways for my diffusive source attempt? Thanks, Chris |
March 6, 2019, 04:24 |
Rep Power: 11 |
Hi Chris!
I am sorry that my english were confusing, I am not a native speaker! I agree with you, that the volume source is essentially an area source, because the normal height of the source cells is not important compared to the other two source dimensions. As far as the option "absolute", it assigns a SINGLE emission rate to the WHOLE source, either if the source consists of 2 cells or 1000 cells, etc. Thus, you get to choose the emission rate, without worrying if your source is e.g. 1.455 or 1.457 m3, because it will apply to the whole source. Last edited by arsenis; March 6, 2019 at 04:35. Reason: improving the english |
fvoptions, scalartransport, semi-implicit-source |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
fvMatrix, fvOptions and SuSp: automatic implicit/explicit source-term treatment | Zeppo | OpenFOAM Programming & Development | 7 | December 15, 2021 10:20 |
topoSet/setSet and fvOptions | pod | OpenFOAM Running, Solving & CFD | 5 | April 30, 2019 05:41 |
New output variable for source term in fvoptions - without changing the solver | vincent.clary | OpenFOAM Programming & Development | 2 | June 26, 2018 05:21 |
twoPhaseEulerFoam fvOptions for alpha | lavdwall | OpenFOAM Running, Solving & CFD | 8 | October 19, 2015 09:57 |
