Lagrangian particle tracking for already solved flows (post-processing mode) |
Rep Power: 9 ![]() |
Hi!
I am trying to run the particle tracking solver icoUncoupledKinematicParcelFoam in post-processing (I already have the flow files). Do you know where I can find some tutorial if any? I have already solved a flow case such as pitzDaily. I myCase/constant folder I have included kinematicCloudProperties and kinematicCloudPositions. I would like to compute the particles tracking in my domain. Is that possible in post-processing mode? Do you have any suggestion? Thank you! |
Ramkumar
Rep Power: 11 ![]() |
Hi, did u get it solved? i am also trying to do similar one, i need something with massless particle tracking for calculating the residence time. I already tried icoUncoupledKinematicParcelFoam but it is working good for mass particles and it also includes other forces like drag and gravity.
I removed gravity, but when i give the particle size to be small, it doesnt even move and when i make it big, it just moves only upto 50% of distance that what actually it has to do. Please help if u find something |
Arnau
Rep Power: 5 ![]() |
Hi, I also want to run a particle tracking simulation on an already solved flow. Did you manage to do it? In affirmative case, how did you do it?
Thanks for your help. Best regards! |
Ramkumar
Hi, i lost my patience in searching for existing particle tracking, hence i developed my own massless particle tracking application on OpenFOAM v1806, which works but quite slow for very large meshes... and sorry buddy i cannot share the code as it is under copyright of the company i worked for..
Nick Howlett
Rep Power: 4 ![]() |
I'm used OpenFOAM's 'particleFoam' solver to run particle tracking after the fluid dynamics have been previously solved. Check out a working case on our GitHub: https://github.com/TessellateDataSci...rticleTracking
kinematiccloudproperties, particle coupling |
Lagrangian particle tracking with a transient carrier flow | Armin.Sh | OpenFOAM Running, Solving & CFD | 10 | January 17, 2022 04:55 |
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 09:36 |
Lagrangian particle tracking - PSI-C | TallesC | CFX | 7 | February 7, 2018 17:05 |
Lagrangian Particle Tracking | cojua8 | OpenFOAM | 0 | February 2, 2018 16:55 |
Request for Lagrangian Particle Tracking Validation or Verification Paper | Mojtaba.a | OpenFOAM Verification & Validation | 6 | May 23, 2016 01:47 |
