Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wrong result using "interpolate" on postProcess cuttingPlane
Old   August 26, 2019, 18:42
Default wrong result using "interpolate" on postProcess cuttingPlane
Za-ck is on a distinguished road
I would like to plot the alpha field on a cutting plane using the runTimePostProcessing tool. Everything looks right without interpolation, but with activated interpolation the values seems to get mixed up. Same error on an isoSurface. No problems using a plane instead of a cuttingPlane.
Any ideas?
Cheers,
Za-ck
|  \\    /   O peration     | Version:  v1906                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
	version     1906;
	format      ascii;
	class       dictionary;
	location    "system";
	object      visualization;
functions
    planes
        type            surfaces;
        libs            ("libsampling.so");
        writeControl    writeTime;
        writeFields     true;
        fields          (alpha.water);
        surfaceFormat   none;
        store           true;
        //cell cellPatchConstrained cellPoint cellPointFace cellPointWallModified pointMVC
        interpolationScheme cellPoint;
        surfaces
            xPlane
                type            cuttingPlane; //plane; //
                planeType       pointAndNormal;
                interpolate     true;
//                 regularise      false;
                pointAndNormalDict
                    point   (0 0 0);
                    normal  (1 0 0);
    postPro1
        #includeEtc "caseDicts/postProcessing/visualization/runTimePostPro.cfg"
        // Time control etc
        output
            name        image;
            width       1920;
            height      1200;
        camera
            nFrameTotal     1;
            parallelProjection  no;
            position        (-20 0 0);
            focalPoint      (-1 0 0.0);
            up              (0.0 0.0 1.0);
        // Default colours
        colours
            ${..colourScheme.paraview};
        surfaces
            //A cutting plane from sampled surfaces:
            stored1
                type            functionObjectSurface;
                functionObject  planes.xPlane; //planes.freeSurface; //planes.test2; //
                colourMap       coolToWarm;
                representation  surface;
                visible         yes;
                featureEdges    no;
                colourBy        field;
                field           alpha.water;
                range           (0.0 1.0);
                opacity         1;
        text
Za-ck is offline   Reply With Quote
Old   August 28, 2019, 10:08
tecmul is on a distinguished road
I'm confused about what the "interpolate" switch does. Doesn't sampling on a plane always need some form of interpolation?
tecmul is offline   Reply With Quote
Ansys outputs obviously wrong result on a simple static mechanical problem, why? cli21 Structural Mechanics 6 March 23, 2017 13:40
Wrong result Heat Transfer in a Cavity abhinav.abhi19 FLUENT 5 February 21, 2014 11:31
Pressure result wrong!!!!!!! lehoanganh07 FLUENT 4 January 10, 2014 08:20
How to plot variable (alpha1) on cuttingPlane (runtime postprocessing) pythag0ra5 OpenFOAM Post-Processing 1 September 26, 2013 08:46
Wrong result with bilinear interpolation zonexo Main CFD Forum 1 June 12, 2007 15:55
