Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Velocity fields and probes do not match up
Old   October 31, 2019, 03:52
Default Velocity fields and probes do not match up
Nat K
nskelly is on a distinguished road
I ran some LES simulations of turbulent flow over a backward facing step. I was aiming to calculate turbulence parameters, velocity fluctuations, turbulent kinetic energy and turbulence intensity through time. To do so I put a number of probes in the computational domain to obtain velocity through time at various points of interest.
However, when I compare the velocity obtained by the probe to the fields that are saved in my timestep folders, the velocity values are different. Therefore, the results in different TKE and turbulence intensity.
Would anyone why this would be? Is it part of some sort of interpolation of the values from where the probes are located?
Thanks in advance
nskelly is offline   Reply With Quote
Old   November 1, 2019, 13:07
KTG
Abe
KTG is on a distinguished road
You should post an example of what you mean and the function object you ran. Interpolation is an option that you would have specified in the function object.
KTG is offline   Reply With Quote
probe function, turbulent kinetic energy, velocity
Error in Reading Velocity at each time step while using TimeVarryingMappedFixedValue faiazk OpenFOAM Running, Solving & CFD 3 October 1, 2018 15:04
[OpenFOAM] Probes function gives different values than ParaView Bazinga ParaView 4 November 29, 2017 13:59
How many probes can I have in a simulation ? guilha OpenFOAM Post-Processing 13 September 17, 2016 07:26
probes function not working in Openfoam 2.1.1 nandiganavishal OpenFOAM 7 July 26, 2012 11:06
Resolving Velocity Magnitudes with Probes steph79 OpenFOAM 2 August 9, 2010 18:16
