January 6, 2020, 06:27 |
Extension of geometry after simulation [SOLVED]
Patrick
Hello everyone
I am looking for a special function to change the simulated geometry. Current state: I am simulating a cuboid geometry with an inlet at the top and an outlet. Searched function: After a while I want to pause my simulation and add a new layer on top of my geometry with new cells. The inlet has to be moved to the new top cells. Then I want to continue the simulation. If someone has an idea if there is such a function, I would be very grateful for any hint. Patrick Last edited by PH900; January 7, 2020 at 07:22. Reason: Solved |
January 7, 2020, 07:20 |
Solved
Patrick
Hi everyone
I solved my problem with the mapFields utility. https://cfd.direct/openfoam/user-guide/v6-mapfields/ Patrick |
add layers, change / changing, geometry, geometry change |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
Best software for centrifugal fan (rotating geometry) simulation | DRoam | Main CFD Forum | 0 | November 18, 2016 16:12 |
2D simulation on symmetry plane of 3D geometry | henrikdahlberg | ANSYS Meshing & Geometry | 0 | October 17, 2013 12:35 |
[ICEM] Geometry cleaning to use a multidomain simulation | Attesz | ANSYS Meshing & Geometry | 1 | October 20, 2009 09:38 |
Export geometry in workbench from simulation. | kezman | ANSYS Meshing & Geometry | 1 | October 14, 2009 14:06 |
