May 8, 2020, 09:21 |
Animate cutting plane
Sam
I want to know if there is a way to generate animations with cutting planes. I can get the individual folders for the timesteps but can't seem to generate an animation with it in paraview.
May 12, 2020, 16:35 |
Herpes Free Engineer
Rep Power: 12 |
- For making videos in postprocessing phase, if you are not familiar with other more powerful Unix tools, you can try to use "foamCreateVideo" script of OpenFOAM. Please search for it. - For making videos in runtime, you can use runTimePostprocessing function object (another link).
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
[Commercial meshers] faceSet of a cutting plane for a internal patch definition | RubenGutiii | OpenFOAM Meshing & Mesh Conversion | 1 | April 17, 2019 05:10 |
Measure the surface of the faces of a triangulated cutting plane | Pagoda | OpenFOAM Post-Processing | 3 | August 20, 2018 09:51 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
animate on plane | hakkż | FLUENT | 2 | August 25, 2003 13:58 |
