Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
PostProcessing folder not updated on convergence
Old   July 23, 2020, 09:22
Default PostProcessing folder not updated on convergence
Ben Simpson
b.simpson is on a distinguished road
My OpenFOAM model is writing data at the defined writeTime in my controlDict but it is not writing the final simulation data to the PostProcessing folder when the convergence criteria is met. Does anyone have any idea what is causing this?
For information, I am running buoyantSimpleFoam using the OpenFOAM-dev version. I have several volFieldValue, fieldMinMax and surfaces called in my functionObjects. In my last simulation run, these were writen to the PostProcessing folder at times 1000, 2000, and 3000 but not when the simulation converged at time 3917.
Below is my controlDict:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     buoyantSimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         7000;
deltaT          1;
writeControl    timeStep;
writeInterval   1000;
purgeWrite      1;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
/*libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
functions
	#include "surfaces"
	fieldMinMax
		type                fieldMinMax;
		libs  				("libfieldFunctionObjects.so");
		log                 yes;
		writeControl       	writeTime;
		//writeInterval      	1;
		//mode              magnitude;
		fields             	( U p T rho CO2);
	CO2
			type    			scalarTransport;
			libs 				("libsolverFunctionObjects.so");
			writeInterval      	1;
			active          	true;
			autoSchemes     	false;
			nCorr           	0;
			resetOnStartUp 		false;
			field				CO2;
			fvOptions
	comfortAnalysis
			type            comfort;
			metabolicRate	1.2;
			clothing		0.9;
			extWork			0.0;
			executeControl  writeTime;
	/*modelAverages
			type            volFieldValue;
			log				true;
			writeFields		true;
			source			all;
			operation		volAverage;
			fields
				T
				CO2
				U
	breathingZoneAverages
			type            volFieldValue;
			log				true;
			writeFields		true;
			regionType		cellZone;
			name			breathingZone;
			fields
				T
				CO2
				U
				PMV
				PPD
	spaceAverage
			type            volFieldValue;
			log				true;
			writeFields		true;
			name			spaceZone;
			fields
				T
				CO2
				U
	/*testAverage
			type            volFieldValue;
			log				true;
			writeFields		true;
			name			localTest;
			fields
				T
				CO2
Thank you in advance for any support you can provide me with solving this issue.
Kind regards,
Ben
b.simpson is offline   Reply With Quote
buoyantsimplefoam, openfoam-dev, postprocessing
Low Mach number wing/body junction convergence Zen SU2 6 May 3, 2019 04:51
CFX overwhelming Fluent in mass convergence of boundary layer separation case Pierre1 FLUENT 7 March 26, 2015 21:43
Problems with convergence with an easy system franzdrs Main CFD Forum 0 June 15, 2009 18:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
