August 18, 2020, 14:02 |
Velocity contour at the edge of refined area
Hi
I ran an LES simulation. Everything is normal except the weird velocity contour at the edge of the refined area. The whole simulation ran completely with meaningful results but this area of high velocity does not make sense to me. Do you think if there is an issue with Paraview when I load data? Or something else? There is nothing at the edge of the refined area and that high-velocity area should not happen. Any help is appreciated. Reza |
openfoam, sowfa, turbine, velocity, windfarm |
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour | Caster_Troy | FLUENT | 1 | December 7, 2017 06:19 |
Axial Velocity Contour in non-planar bend | omidmd | FLUENT | 2 | October 7, 2014 14:22 |
Axial Velocity Contour in non-planar bend | omidmd | CFX | 2 | August 4, 2014 13:04 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
The trailing edge velocity | maximus | Main CFD Forum | 0 | March 6, 2005 00:27 |
