How to use the output of a function object as an input to another one? |
September 17, 2020, 01:03 |
Ali Shayegh
Rep Power: 10 |
I want to use an average pressure at a section as a reference pressure for pressure coefficient calculation. I have included the following function objects in my controlDict for pressure averaging and calculation of Cp: Code:
averagedPressure { type surfaceFieldValue; libs (fieldFunctionObjects); enabled true; writeControl onEnd; executeControl onEnd; writeFields true; result pRef; surfaceFormat none; regionType sampledSurface; name sampledP; sampledSurfaceDict { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (-1.7 0 0.4); normal (1 0 0); } interpolate true; } operation areaAverage; fields ( p ); } pressure { type pressure; libs (fieldFunctionObjects); executeControl onEnd; writeControl onEnd; result Cp; mode staticCoeff; rho rhoInf; rhoInf 1.0; pInf 0; U UInf; UInf (1 0 0); } Ali |
February 17, 2021, 14:49 |
Adrian Rouco
Rep Power: 8 |
Have you achieved a solution, I am facing the same problem
February 22, 2021, 03:18 |
Ali Shayegh
Rep Power: 10 |
No, but it was not due to that it is not possible, but because of my limited amount of time.
Instead, I ran the case one time in order to obtain the average pressure in the reference section, then ran it again and used the calculated reference pressure as pInf. |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
