Error in Coefficient of Lift value for Porous Media with Buoyancy |
August 1, 2017, 03:40 |
Anirudh Kulkarni
Rep Power: 10 |
Dear Foamers,
I have been trying to simulate flow across a porous square heated cylinder, subjected to buoyancy. I am using BuoyantBoussinesqPimpleFoam with explicitPorositySource via fvOptions. I have attached the case file for reference. (BlockMesh + TopoSet + SetFields before trying simulation) Now, I am getting negative lift variation, as per the literature, for solid cylinder (see solid.png in attachment). When I introduce porous cylinder instead of solid, the drag variation remains same, but the lift coefficient values (see porous.png in attachment) jump near zero, which is way off the literture value. The case that I have attached is at Ri = 0.5 and Re = 40 and the coefficient of lift (average) should be near -1. I have also attached the lift coefficient variation. What can be the reason for this variation in Cl values and how can I solve it? I have tried almost all variations in putting the Boussinesq approximation into the code, but nothing seems to work out. Please help me out. Thanks in advance. P.S. The axis for Cl curve is on RHS. Last edited by Tempest; August 1, 2017 at 07:51. |
November 20, 2020, 10:05 |
damu
Rep Power: 9 |
Dear Anirudh,
I have issues while simulating flow over a heated cylinder. Since you have successfully simulated the solid cylinder case, I would be grateful to have your suggestions. buoyantBoussinesqPimpleFoam as such is not giving me negative lift coefficients. Also, the wake is not getting captured properly. Did you have any such issues? Please let me know. Thank you |
buoyantbousspimplefoam, coefficient of lift, openfoam 2.1.0, porous media flow |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 16:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 11:48 |
