February 3, 2021, 11:17 |
Forces in InterFoam
Federico
Rep Power: 5 |
Hello everybody,
I have a geometry inside my domain in which both air and water are presents and I want calculate the force acting on it. I read that I should put rhoName rho to calculate the force depending on the fluid present in a specific area, is that true and is this file correct? The output will be the totale force but if I want only the force by the water? file_name { type forces; libs ( "libforces.so" ); writeControl timeStep; writeInterval 1; patches (patch); rhoName rho; // Considers each fluid pRef 1e5; log true; CofR (0 0 4.5e-3); pitchAxis (0 -1 0); } |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
forces functionObject with interFoam and dynamic pressure | AnnaF | OpenFOAM Post-Processing | 4 | June 20, 2019 20:46 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
Measure forces on wall with interFoam | jrrygg | OpenFOAM Pre-Processing | 0 | November 5, 2012 08:20 |
forces in interFoam | Svensson | OpenFOAM Post-Processing | 2 | May 9, 2012 13:31 |
