icoUncoupledKinematicCloud postprocess
Like Tree1Likes
  • 1 Post By alainislas
Old   April 18, 2021, 14:25
Default icoUncoupledKinematicCloud postprocess
Arnau
arnauvp is on a distinguished road
Hi, I have simulated the flow thrrough a channel using pimpleFoam and I have added the particle tracking tool icoUncoupledKinematicCloud. In order to post process the results I need the position of the particles at each time step.
After the simulation, for each time step, a lagrangian folder is created, wich includes kinematicCloud properties in a folder. I think I can understand the output format of practically all the output files, except the position one. I expected to find the coordinates of each particle, or the control volume where each particle is located, but I am getting this output format for each particle.
(0.776997 0.172103 0.00169238 0.0492071) 176923 525202 1
If someone can help me to identify this output format I would be really gratefful.
Thank you for your attention and best regards.
arnauvp is offline   Reply With Quote
Old   April 19, 2021, 03:21
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Well, it's been some time since the code version of the OpenFoam foundation switched from cartesian coordinates to barycentric coordinates.
What I do is to open the lagrangian phase in paraview and then export to .csv which will give you the 3 coordinates. If you have lots of data you can create a python script to automatize this.
Please look at this thread and to this site
arnauvp likes this.
alainislas is offline   Reply With Quote
Old   April 19, 2021, 08:39
Arnau
Thank you very much! This will be very useful to me
Old   May 12, 2021, 15:15
Default icoUncoupledKinematicCloud on pre solved flow
Arnau
Hi again, I would like to ask another question related to the particle tracking tool. In the case of non-coupled particle-flow relation, how can i solve the particle tracking on a previously solved flow?
icouncoupledkinematic, lagrangian, particle tracking, position, postprocess
postProcess Utility: icoFoam -noFunctionObjects Why?How? TeresaT OpenFOAM Post-Processing 8 July 26, 2023 02:41
codedFunctionObject -postProcess -- not possible?? JM27 OpenFOAM Post-Processing 0 November 8, 2020 13:30
postProcess calculate Tdeg jonfah OpenFOAM Post-Processing 2 November 1, 2018 06:07
postprocess: symbol lookup error BenAsbo626 OpenFOAM Post-Processing 2 October 26, 2018 13:28
postProcess functionality in openFOAM 4 bullmut OpenFOAM Post-Processing 23 July 21, 2017 09:11
