June 15, 2021, 12:22 |
Pressure difference along a streamlined body
Hello people!
I'm trying to evaluate pressure difference along a streamlined body located in a closed channel. It could be calculated between to specified cells/points on the body or along the surface line. The surface is described by a known function (NACA-profile). For the time being, I look at an example about the pressure difference across internal faces (Pressure difference across 2 internal faces), but couldn't figure it out for my case. As I'm quite new to openFoam, every answer is helpful Solver is PimpleFoam. Thank you for the help! Best regards, Henrik Last edited by Hendrix; June 16, 2021 at 07:33. |
pressure, pressure difference, streamline body |
How is total pressure calculated? | looee | CFX | 15 | October 30, 2019 08:14 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
