Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Wrong temperatures with postProcess functions
Old   October 6, 2021, 10:27
Default Wrong temperatures with postProcess functions
Adrian Kwiatkowski
akwiatek is on a distinguished road
Hello everyone!
I'm trying to postProcess a case by using linear and surface sampling and I recieved wrong results of temperature, the temperature is equal to 193K in whole domain, while the other quantities seemes to be fine. I checked the time/T results itself and numbers there are fine, paraview does not have any troubles with opening it.
Functions inside controlDict
functions
    #includeFunc mag(U)
    linesample
        type                      sets;
        libs                  (sampling);
        writeControl              timeStep;
             outputInterval            500;
          interpolationScheme       cellPoint;
           setFormat             csv;
           sets
                 line_horiz_1
                  type            uniform;
                  axis            x;
                  start           (0 -0.05 0.100);
                  end             (4.525 -0.05 0.100);
                  nPoints         1000;
            line_horiz_2
                  type            uniform;
                  axis            x;
                  start           (0 -0.05 1.905);
                  end             (4.525 -0.05 1.95);
                  nPoints         1000;
            line_horiz_3
                  type            uniform;
                  axis            x;
                  start           (0 -1.975 1.905);
                  end             (4.525 -1.975 1.95);
                  nPoints         1000;
            line_horiz_4
                  type            uniform;
                  axis            x;
                  start           (0 -1.975 0.100);
                  end             (4.525 -1.975 0.100);
                  nPoints         1000;
            line_vert_1
                  type            uniform;
                  axis            z;
                  start           (0.1 -1.975 0);
                  end             (0.1 -1.975 2.05);
                  nPoints         1000;
            line_vert_2
                  type            uniform;
                  axis            z;
                  start           (4.425 -1.975 0);
                  end             (4.425 -1.975 2.05);
                  nPoints         1000;
            line_vert_3
                  type            uniform;
                  axis            z;
                  start           (0.1 -0.05 0);
                  end             (0.1 -0.05 2.05);
                  nPoints         1000;
            line_vert_4
                  type            uniform;
                  axis            z;
                  start           (4.425 -0.05 0);
                  end             (4.425 -0.05 2.05);
                  nPoints         1000;
            Measurment_points
            type            cloud;
            axis             xyz;
            points            ((0.1 -0.05 0.1) (0.1 -1.975 0.1) (0.1 -0.05 1.95) (0.1 -1.975 1.95) (4.425 -0.05 0.1) (4.425 -1.975 0.1) (4.425 -0.05 1.95) (4.425 -1.975 1.95));
          fields                  (T mag(U) p p_rgh U);
    Measurment_points
        type            cloud;
        axis             xyz;
        points            ((0.1 -0.1 0.1) (0.1 -1.925 0.1) (0.1 -0.1 1.95) (0.1 -1.925 1.95) (4.425 -0.1 0.1) (4.425 -1.925 0.1) (4.425 -0.1 1.95) (4.425 -1.925 1.95));
        setFormat        csv;
        outputInterval          500;
        fields                  (T mag(U) p p_rgh );
    Surfaces
        type            surfaces;
        libs            (sampling);
        surfaceFormat        vtk;
        outputInterval          500;
        surfaces
            surface4
                type        plane;
                planeType       pointAndNormal;
                pointAndNormalDict
                point    (0.1 -0.05 0.1);
                normal    (0 1 0 );
                triangulate    true;
            surface3
                type        plane;
                pointAndNormalDict
                normal    (0 0 1 );
                triangulate    false;
            surface5
                type        plane;
                pointAndNormalDict
                normal    (1 0 0 );
                triangulate    false;
            surface2
                type        plane;
                pointAndNormalDict
                point    (4.425 -1.975 1.95);
                normal    (0 1 0 );
                triangulate    false;
            surface1
                type        plane;
                pointAndNormalDict
                normal    (0 0 1 );
                triangulate    false;
            surface6
                type        plane;
                pointAndNormalDict
                normal    (1 0 0 );
                triangulate    false;
I uploaded exemplary results, unfortunately I can't upload the T results itself because the file is to big.
If anyone had the same problem or know the solution please let me know.
Thank you all in advance!
Adrian
akwiatek is offline   Reply With Quote
buoyantsimplefoam, openfaom, sample postprocessing, temperature
postprocess: symbol lookup error BenAsbo626 OpenFOAM Post-Processing 2 October 26, 2018 13:28
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
How to calculate node temperatures from cell temperatures? h0rst FLUENT 2 May 28, 2017 00:15
fully developed channel flow with kOmega, wrong results boshynova OpenFOAM Programming & Development 1 April 20, 2016 10:54
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 10:45
