September 20, 2011, 11:16 |
sampleDict - Problems with distanceSurface
Taylorreihe
Rep Power: 15 |
I try to sample my velocity data with distanceSurface (using OF 201) and getting this error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : sample -latestTime Date : Sep 20 2011 Time : 16:41:39 Host : ThinkPad-X40 PID : 3895 Case : /home/kiro/OpenFOAM/kiro-2.0.1/run/askervein_hill/ask_mesh1_2sphere_SST nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 10203 Reading surface description: topology_askervein.stl Time = 10203 --> FOAM FATAL ERROR: getVolumeType failure, neither INSIDE or OUTSIDE From function void Foam::distanceSurface::createGeometry() in file sampledSurface/distanceSurface/distanceSurface.C at line 168. FOAM exiting Because when I try to sample the same case with OF17 it runs fine (without any errors), but the results are verry weird! Here are my sampleDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // setFormat raw; surfaceFormat raw; interpolationScheme cellPointFace; fields ( U ); sets ( ); surfaces ( topology_askervein.stl { type distanceSurface; surfaceType triSurfaceMesh; distance 10; signed true; } ); // ************************************************************************* // Kris |
December 13, 2011, 05:56 |
did you ever get a reply?
Hanan Einav-Levy
Rep Power: 15 |
Hi Kris,
I'm trying to use distanceSurface to sample at specific heights above my surface, for flow simulation in the atmospheric boundary layer - exactly what you are doing (according to the name of you stl file). Did you ever solve your problem? I have some additional questions , but first thing first, hope you answer. Hanan. |
September 27, 2017, 03:20 |
Hi Hanan,
After so many years, do you have a solution for this problem? Regards, Aaron |
March 3, 2022, 04:54 |
Extract the surface from the bottom patch
Clara
Rep Power: 15 |
A good solution that worked like charm for me was to first convert the bottom (terrain) patch into an stl, then move it to the height of interest:
surfaceMeshTriangulate -patches "(Terrain)" Terrain_frompatch.stl surfaceTransformPoints -translate '(0 0 h)' Terrain_frompatch.stl Sampling_surface.stl Where h is your desired height. The resulting surface will have the same mesh resolution as your patch, so if you mesh is okish, your surface sampling should be too. Then you just do a typical triSurfaceMesh sampling: Terrain_ph { // Sampling on triSurface type triSurfaceMesh; surface Sampling_surface.stl; source cells; interpolate false; } Cheers |
May 26, 2022, 19:38 |
Angel Monsalve
Rep Power: 16 |
12 years later...
I just had that problem. I have used this method for a long time and today was the first time that I run into this problem. The reason is actually in the error message. OpenFOAM can't determine what region is Inside or Outside your stl file. In my case, when it worked, I always used shell-type surfaces. Therefore, the definition of insider and outside is within the postprocess function. Most likely you are using an "actual" surface, at least that was my case. So, the solution is pretty simple, set Signed as False. That should do it. This is what my Dict looks like type surfaces; libs ("libsampling.so"); surfaceFormat raw; interpolationScheme pointMVC; fields ( UPrime2Mean R k UMean ); surfaces ( h_10Percent { // Isosurface from signed/unsigned distance to surface type distanceSurface; signed false; // Definition of surface surfaceType triSurfaceMesh; surfaceName Q3_h1.stl; // Distance to surface distance 0.001; //cell false;// optional: use isoSurface instead // of isoSurfaceCell interpolate true; regularise false; // Optional: do not simplify // mergeTol 1e-10; // Optional: fraction of mesh bounding box // to merge points (default=1e-6) } ); Hope this helps someone in the future. |
May 30, 2022, 11:58 |
angelmonsalve:
By pure chance I had the same issue in the last couple of days, and was able to solve it using "signed false;". Thank you my man/woman! |
June 14, 2022, 04:33 |
#7 | |
Mark Olesen
Rep Power: 40 |
Using "signed false" will then create an envelope at the given distance away from the surface which may not be what you want for many cases. If you have a distance identical to "0", this is really ill-advised since you most definitely need the sign to get the proper cell cuts. As a side-note: if you have a distance of "0", you will normally get a variety of special handling for at the edges of the surface, which you need to avoid having the distance surface become infinitely large, but also to avoid "ragged" edges. https://develop.openfoam.com/Develop...feebb874d7fae2 |
sampledict, sampling |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
problems with midPoint set sampling | grandgo | OpenFOAM Bugs | 6 | December 13, 2011 09:34 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
unstructured grid | sreekanth | Main CFD Forum | 1 | August 6, 2001 15:09 |
