Rep Power: 8 ![]() |
hi all,
i searched up the forum about this issue, but could not find a satisfactory explanation. i would like to know what the mass imbalance is in every iteration step for a steady state calculation with simpleFoam. 1.normally, for an incompressible, steady state case the continuity equation would be: div(U)=0. from the computational side this equation should be div(U)=r, meaning there should be a residual r in every iteration. 2. Integral of div(U) over a control volume is equal to integral over the bounding surface of this control volume when Gauss theorem is applied: Integral(div(U))dV=Integral(U_f*vector_n)dS, further this Integral can be discretized for a polyhedra -> SumOverAllFaces(U_f*vector_n*faceArea). This sum should be 0 ideally, but will give a residual r for every iteration step, which could be viewed as the mass imbalance for each cell. i want to compute and output exactly this value. so the question is, what do i need to do to compute this mass imbalance. i know that there is the postprocessing utility "div". i did execute div(U) and div(phi) for icofoam. both values differ from each other (in this thread Meaning of "fvc::div(phi)" , post #20, it is claimed that both should give the same value). the dimension for both is 1/second. i did calculate div(U) values with excel for this case manually, and got the same values which are shown in paraview. i hope anybody can tell me how to compute the mass imbalance correctly. |
Hrvoje Jasak
Rep Power: 33 ![]() |
fvc::div(phi) is the right thing to do. If you need a smaller error, tighten the pressure solver tolerance.
Face flux phi is the face representation of the velocity field and this is what we apply the div(u) constraint on. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk Last edited by hjasak; June 22, 2022 at 08:52. |
Thank you Prof. Jasak.
What confuses me is that div(phi) has the dimension "per second" in the output-file. I don't know how to interpret that, do i need to multiply that value with the cell volume to get the volume flux imbalance and maybe that again with the density to get the mass imbalance in kg/second? Thanks again for any advice. |
Shenhui Ruan
Rep Power: 4 ![]() |
Hello geth03,
You can read the following two answers: Meaning of "fvc::div(phi)" the difference between div(U) and div(phi) They already talked a lot. |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
mass imbalance at the inlet, interface, outlet | CFDturbomachinery | CFX | 2 | October 30, 2014 11:54 |
Mass imbalance in fast chem. reaction | Laexzzz | FLUENT | 3 | March 16, 2014 23:19 |
Integral of mass Imbalance drops with time | TfG | FLUENT | 0 | April 3, 2009 11:38 |
OutletBoundary Condition Causes Mass Imbalance | Andy | Main CFD Forum | 0 | March 11, 2004 14:05 |
