NACA 2412 - high drag values, error reconstructPar |
October 25, 2022, 18:03 |
Airfoil error with finer refinement
Max
with 5.600.000 Cells, I'm getting good results for my NACA 2412 validation. If I'm going for more cells with a finer refinement box, the simulation crashes. I use simpleFoam with a Reynolds Number of 3,1*10^6 (v=73.7 m/s) for validation. The wing has infinite wing span (chord: 3ft, span:2ft). To check, if a can get a mesh independent solution, i need a mesh with more cells. SnappyHexMesh runs without any errors and creates 15.000.000 cells in my case. Then the errors begin with patchsummary.log. The relevant logs are in attatched. Everything works fine, when i set the refinement box under a value of 3. Can someone tell me, why this happens? Iam grateful for every answer. Last edited by max_307; October 29, 2022 at 15:40. |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
High drag coefficient Cd values | czhongrong | OpenFOAM Post-Processing | 0 | December 5, 2015 22:49 |
Lift and Drag Coefficient data for NACA 2412 Airfoil | mahbub03 | Main CFD Forum | 22 | May 25, 2014 15:39 |
Symmetric NACA Airfoil Lift and Drag Data | jrider22 | Main CFD Forum | 3 | April 15, 2010 04:59 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
