Sreehari Perumanath
Rep Power: 5 ![]() |
Hi Foamers,
Hope you're having a great time. I'm using Paraview 5.9.1 and whenever I open a simulation in it, the entire simulation box is covered in some shadow. Please see the image here: ![]() https://www.dropbox.com/s/fdu9y2dj7o...24.55.png?dl=0 If I zoom out, eventually the shadow disappears completely. But, by then, the domain would be barely visible. Does anyone have any suggestion on how to get rid of this shadow effect? It would be very helpful. Many thanks, SP |
Sreehari Perumanath
NVM, solved it. In case you're here for the solution: the problem arose because the lighting was off. I turned off the light kit and everything looks fine now. Check here: https://discourse.paraview.org/t/lig...-paraview/9089
S |
paraview, paraview 5.0, shadow |
Display Modes | |
Mathematical meaning of window averaging in fieldAverage functionObject | Tobermory | OpenFOAM Post-Processing | 2 | December 31, 2022 09:44 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 12:51 |
[ICEM] Script file : how to reset all, fit window, etc. | macfly | ANSYS Meshing & Geometry | 0 | July 25, 2012 11:07 |
[OpenFOAM] New window is hidden behind geometry window | Wenani34 | ParaView | 0 | March 12, 2010 08:50 |
