How to extract data from specific domain instead of whole domain |
August 28, 2023, 03:07 |
Mach
Rep Power: 3 |
Hell everyone!
I would like to extract data near airfoil for particular study rather than to work on full domain data because it is too much resource consuming. Can you help me with any function present in openfoam for this particular task or in paraview. |
August 28, 2023, 03:26 |
Yann
Rep Power: 26 |
In ParaView you can use the clip filter, with a "clip type: box" for instance to clip your domain and keep only the part you want to work with. Cheers, Yann |
August 28, 2023, 12:32 |
#3 | |
Mark Olesen
Rep Power: 40 |
One option would be to specify the restricted region and generate output files during the simulation. Would normally recommend the ensightWrite functionObject (for small output sizes with a static mesh), but the vtkWrite functionObject would work equally well. If you check the documentation of ensightWrite, you will see that it supports a geometric selection mechanism: Code:
selection { box { action use; source box; box (-0.1 -0.01 -0.1) (0.1 0.30 0.1); } dome { action add; shape sphere; origin (-0.1 -0.01 -0.1); radius 0.25; } centre { action subtract; source sphere; origin (-0.1 -0.01 -0.1); radius 0.1; } blob { action add; source surface; surface triSurfaceMesh; name blob.stl; } } With these functionObjects, you can specify which fields you wish to output as well. |
August 30, 2023, 02:04 |
Mach
Rep Power: 3 |
Thank You Yann, I got the desired result through this first applying clip then slice over it. Now I am trying get the data of every snapshot in one csv file , do you know any command for that or we have to write a python script?
August 30, 2023, 02:09 |
#5 | |
Mach
Rep Power: 3 |
airfoil, domain, postprocess |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
Extract data at a specific depth | reespanau | OpenFOAM Post-Processing | 1 | May 15, 2023 06:45 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
