Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to extract data from specific domain instead of whole domain
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By olesen
Old   August 28, 2023, 03:07
Red face How to extract data from specific domain instead of whole domain
Mach
MachEpoch is on a distinguished road
Hell everyone!
I would like to extract data near airfoil for particular study rather than to work on full domain data because it is too much resource consuming. Can you help me with any function present in openfoam for this particular task or in paraview.
File Type: jpg Screenshot from 2023-08-28 12-34-14.jpg (88.7 KB, 8 views)
MachEpoch is offline   Reply With Quote
Old   August 28, 2023, 03:26
Yann
Yann will become famous soon enough
In ParaView you can use the clip filter, with a "clip type: box" for instance to clip your domain and keep only the part you want to work with.
Cheers,
Yann
MachEpoch likes this.
Yann is online now   Reply With Quote
Old   August 28, 2023, 12:32
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by MachEpoch View Post
Hell everyone!
One option would be to specify the restricted region and generate output files during the simulation. Would normally recommend the ensightWrite functionObject (for small output sizes with a static mesh), but the vtkWrite functionObject would work equally well.
If you check the documentation of ensightWrite, you will see that it supports a geometric selection mechanism:
        selection
            box
                action  use;
                source  box;
                box     (-0.1 -0.01 -0.1) (0.1 0.30 0.1);
            dome
                action  add;
                shape   sphere;
                origin  (-0.1 -0.01 -0.1);
                radius  0.25;
            centre
                action  subtract;
                source  sphere;
                radius  0.1;
            blob
                action  add;
                source  surface;
                surface triSurfaceMesh;
                name    blob.stl;
Since these are also very much like topoSet, you can add/subset cellZones, cellSets etc.
With these functionObjects, you can specify which fields you wish to output as well.
saeed jamshidi likes this.
olesen is online now   Reply With Quote
Old   August 30, 2023, 02:04
Mach
Cheers,
Yann
Thank You Yann, I got the desired result through this first applying clip then slice over it. Now I am trying get the data of every snapshot in one csv file , do you know any command for that or we have to write a python script?
Old   August 30, 2023, 02:09
Mach
        selection
            box
                action  use;
                source  box;
            dome
                action  add;
                shape   sphere;
                radius  0.25;
            centre
                action  subtract;
                source  sphere;
                radius  0.1;
            blob
                action  add;
                source  surface;
                name    blob.stl;
Thanks, I tried vtkWrite for this. I got some result butI was unable to verify that i am choosing correct region for my study. i am still looking over this. thanks for suggestion.
airfoil, domain, postprocess
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 09:49
Extract data at a specific depth reespanau OpenFOAM Post-Processing 1 May 15, 2023 06:45
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 08:09
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
