April 10, 2024, 04:36 |
checkMesh error after reconstructParMesh
Marius
Rep Power: 3 |
I run into some errors when running checkMesh after using reconstructParMesh. I also ran checkMesh before reconstructParMesh and it finished fine without any errors. I am not sure how to fix that now? Here are the two checkMesh results. Before reconstructParMesh: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _c39a0f64-20231220 OPENFOAM=2312 version=2312 Arch : "LSB;label=32;scalar=64" Exec : checkMesh -allGeometry -allTopology Date : Apr 10 2024 Time : 01:36:00 Host : f47623f43039 PID : 1459 I/O : uncollated Case : /home/openfoam/CFD-Openfoam/Clio2024-2 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 5526661 faces: 16326000 internal faces: 16074000 cells: 5400000 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 5400000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box frontAndBack 36000 36722 ok (non-closed singly connected) (-15 -5 -1) (30 5 3) inlet 18000 18361 ok (non-closed singly connected) (-15 -5 -1) (-15 5 3) outlet 18000 18361 ok (non-closed singly connected) (30 -5 -1) (30 5 3) lowerWall 90000 90601 ok (non-closed singly connected) (-15 -5 -1) (30 5 -1) upperWall 90000 90601 ok (non-closed singly connected) (-15 -5 3) (30 5 3) ".*" 252000 252002 ok (closed singly connected) (-15 -5 -1) (30 5 3) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... No pointZones found. Checking geometry... Overall domain bounding box (-15 -5 -1) (30 5 3) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.93603e-18 1.01851e-15 -2.88777e-16) OK. Max cell openness = 3.90313e-16 OK. Max aspect ratio = 4.5 OK. Minimum face area = 0.00222222. Maximum face area = 0.01. Face area magnitudes OK. Min volume = 0.000333333. Max volume = 0.000333333. Total volume = 1800. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 5.47788e-13 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.0333333 0.15 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 1 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.0310652 average: 0.33736 Cell determinant check OK. Concave cell check OK. Face interpolation weight : minimum: 0.5 average: 0.5 Face interpolation weight check OK. Face volume ratio : minimum: 1 average: 1 Face volume ratio check OK. Mesh OK. End After running reconstructParMesh: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _c39a0f64-20231220 OPENFOAM=2312 version=2312 Arch : "LSB;label=32;scalar=64" Exec : checkMesh -allGeometry -allTopology Date : Apr 10 2024 Time : 06:25:19 Host : f47623f43039 PID : 1469 I/O : uncollated Case : /home/openfoam/CFD-Openfoam/Clio2024-2 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 20974724 faces: 53927464 internal faces: 50311460 cells: 16639761 faces per cell: 6.26445 boundary patches: 6 point zones: 1 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 13399550 prisms: 645551 wedges: 1 pyramids: 0 tet wedges: 16833 tetrahedra: 292 polyhedra: 2577534 Breakdown of polyhedra by number of faces: faces number of cells 4 112810 5 157031 6 529654 7 472431 8 127210 9 834428 10 11929 11 10512 12 259655 13 1148 14 2265 15 50933 16 133 17 353 18 6973 19 2 20 4 21 63 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. <<Number of duplicate (not baffle) faces found: 40. This might indicate a problem. <<Number of faces with non-consecutive shared points: 77. This might indicate a problem. <<Writing 194 faces with non-standard edge connectivity to set edgeFaces <<Writing 1 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box frontAndBack 36000 36722 ok (non-closed singly connected) (-15 -5 -1) (30 5 3) inlet 18000 18361 ok (non-closed singly connected) (-15 -5 -1) (-15 5 3) outlet 18000 18361 ok (non-closed singly connected) (30 -5 -1) (30 5 3) lowerWall 90000 90601 ok (non-closed singly connected) (-15 -5 -1) (30 5 -1) upperWall 90000 90601 ok (non-closed singly connected) (-15 -5 3) (30 5 3) clio3rs 3364004 3700790 multiply connected (shared edge) (-0.862136 -0.88747 -4.8231e-05) (3.31436 0.888929 1.47039) ".*" 3616004 3952792 multiply connected (shared edge) (-15 -5 -1) (30 5 3) Detected 1 bad edges (possibly relevant for finite-area) Checking faceZone topology for multiply connected surfaces... No faceZones found. <<Writing 2 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... PointZone PointsBoundingBox frozenPoints 0(1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) Checking geometry... Overall domain bounding box (-15 -5 -1) (30 5 3) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.97747e-16 -1.47266e-15 -9.93147e-15) OK. Max cell openness = 1.609e-15 OK. Max aspect ratio = 189.935 OK. Minimum face area = 1.2264e-09. Maximum face area = 0.0105787. Face area magnitudes OK. Min volume = 1.64322e-11. Max volume = 0.000359184. Total volume = 1794.95. Cell volumes OK. Mesh non-orthogonality Max: 82.0127 average: 16.2043 *Number of severely non-orthogonal (> 70 degrees) faces: 88. Non-orthogonality check OK. <<Writing 88 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 16.9642, 3434 highly skew faces detected which may impair the quality of the results <<Writing 3434 skew faces to set skewFaces Coupled point location match (average 0) OK. ***Error in face tets: 11 faces with low quality or negative volume decomposition tets. <<Writing 11 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces *Edges too small, min/max edge length = 3.01501e-07 0.155124, number too small: 2065 <<Writing 2065 points on short edges to set shortEdges *There are 327518 faces with concave angles between consecutive edges. Max concave angle = 89.5995 degrees. <<Writing 327518 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.121865 average = 0.998712 *There are 26447 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.121865 <<Writing 26447 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 2.68592e-18 average: 0.570997 ***Cells with small determinant (< 0.001) found, number of cells: 21487 <<Writing 21487 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 1451494 <<Writing 1451494 concave cells to set concaveCells Face interpolation weight : minimum: 0.00616374 average: 0.45225 ***Faces with small interpolation weight (< 0.05) found, number of faces: 32023 <<Writing 32023 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.00284747 average: 0.798579 ***Faces with small volume ratio (< 0.01) found, number of faces: 62 <<Writing 62 faces with low volume ratio cells to set lowVolRatioFaces Failed 6 mesh checks. End Should I run snappyHexMesh without decomposePar? But that would take forever... Any help or idea is really appreciated! Thanks. Marius |
April 10, 2024, 04:46 |
Yann
Rep Power: 27 |
Hello Marius,
Your first checkMesh (before reconstructing) should be run in parallel in order to check the parallelized mesh. I guess you meshed your case with snappy. Since you didn't run the first checkMesh in parallel, you actually checked the mesh created by blockMesh, rather than your actual mesh. The 2nd checkMesh (after reconstructing) is the actual check of the mesh you created. Cheers, Yann |
April 10, 2024, 05:11 |
Marius
Rep Power: 3 |
Hello Yann,
thanks for the explanation, that makes sense. Okay, then I need to check how to fix the errors in the mesh. |
April 10, 2024, 06:02 |
Yann
Rep Power: 27 |
I would advise to run checkMesh with the -writeSets vtk option. It will write vtk files containing the errors cells/faces. I can be handy to load it alongside your mesh in paraview to see what's wrong and where.
[Technical] checkMesh is ok, but checkMesh -allGeometry Failed, should I concern that? | mactone | OpenFOAM Meshing & Mesh Conversion | 0 | September 26, 2023 20:23 |
[snappyHexMesh] chekMesh is OK, but checkMesh with options indicates fails | mactone | OpenFOAM Meshing & Mesh Conversion | 2 | September 7, 2022 22:12 |
[Other] CheckMesh vs CheckMesh -allGeometry -allTopology | Nagesh Atreyas | OpenFOAM Meshing & Mesh Conversion | 2 | June 25, 2019 04:55 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
