Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculation of mass flow across a boundary
Like Tree12Likes
Old   February 20, 2012, 23:57
Gopal Shinde
shinde.gopal is on a distinguished road
Hi thr,
I am using version 1.6.
I have included the path in the program calcMassFlow.C.
But still I am getting this error. Plz help.
[shindg2@cd80si0017 calcMassFlow]$ wmake
SOURCE=calcMassFlow.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/edm/shindg2/.PKG/OpenFOAM/OpenFOAM-1.6/src/cfdTools/lnInclude -I/home/edm/shindg2/.PKG/OpenFOAM/OpenFOAM-1.6/src/cfdTools/general/lnInclude -I/home/edm/shindg2/.PKG/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/edm/shindg2/OpenFOAM/shindg2-1.6/Libraries/cellFaceSetUtilities/lnInclude -IlnInclude -I. -I/home/edm/shindg2/.PKG/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/edm/shindg2/.PKG/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/calcMassFlow.o
calcMassFlow.C:36:30: error: FaceSetUtilities.H: No such file or directory
calcMassFlow.C:37: error: ‘FaceSetUtilities’ is not a namespace-name
calcMassFlow.C:37: error: expected namespace-name before ‘;’ token
calcMassFlow.C: In function ‘int main(int, char**)’:
calcMassFlow.C:105: error: ‘flipSet’ was not declared in this scope
calcMassFlow.C:105: error: template argument 1 is invalid
calcMassFlow.C:105: error: invalid type in declaration before ‘=’ token
calcMassFlow.C:105: error: ‘checkFaceSetSides’ was not declared in this scope
calcMassFlow.C:111: error: ‘flips’ cannot be used as a function
make: *** [Make/linux64GccDPOpt/calcMassFlow.o] Error 1
with rgds,
-Gopal.
shinde.gopal is offline   Reply With Quote
Old   February 20, 2012, 23:58
Gopal Shinde
Hi thr,
with rgds,
-Gopal.
Old   February 21, 2012, 08:52
Anne Gerdes
Anne Lincke is on a distinguished road
Hey Gopal,
you are missing a library which is needed for the utility.
Look at this post, they have the same problems:
http://www.cfd-online.com/Forums/ope...massflowc.html
Here you can download the libraries:
http://openfoamwiki.net/index.php/Contrib_calcMassFlow
Follow the instructions which are neccessary for inserting the libraries. Then try it again
Anne
Anne Lincke is offline   Reply With Quote
Old   February 21, 2012, 23:54
Gopal Shinde
Hi Anne,
I have downloaded the required files /libraries. Thanks for the info.
I will give it a try and come back on this forum for some more help.
with rgds,
-Gopal.
Old   April 11, 2012, 14:48
Smile Thanx philippose...
  #25
Deshaka Kottage
Deshaka_Kottage is on a distinguished road
Thanx philippose....It works..really nice work....
Deshaka_Kottage is offline   Reply With Quote
Old   November 21, 2012, 09:28
Paula
curiosity is on a distinguished road
Originally Posted by philippose View Post
Hello Gabriela,
Good evening to you!
Sooo.... here are the steps you need to follow to compile and use calcMassFlow...
I am assuming that you have a working OpenFOAM installation, and that you are able to compile things using wmake....
1. Unzip the file "calcMassFlow.zip" to the folder: [home]/OpenFOAM/[username]-[OFVersion]/applications
2. Go into the created folder "calcMassFlow"
3. type "wmake"
4. The utility compiles, and installs the executable file in the folder:
[home]/OpenFOAM/[username]-[OFVersion]/applications/bin/linuxGCC4DOpt
The above four steps basically complete the compilation / installation of the utility.
To use it... you need to do the following:
1. In the folder "calcMassFlow" mentioned earlier, there is a sample "calcMassFlowDict" file.... copy this file into the "system" folder of your case.
2. Modify the entries under "patchNames" to the names of the patches through which you want to calculate the massflow.
3. Optionally, you can uncomment the "rho" line, and specify the density of the medium you simulated, in case you want the massflow in units "kg/s" instead of "m^3/s"
4. Go to the root folder of your case, and as usual, type:
calcMassFlow <root> <case> [-time t]
or
calcMassFlow <root> <case> [-latestTime]
or
That should be it....
Hope everything works as expected :-)!
Enjoy!
Philippose
Hi all,
I´ve made what Philippose told and I´ve been able to compile it, but when I execute de command calcMassFlowDic I´ve got a message error related with the variable phi:
Error... Patch: Name_of_my_Boundary not found
No phi for Time=4000 -> Skipping
Can anyone help me, please?
curiosity is offline   Reply With Quote
Old   November 21, 2012, 10:29
Paula
Originally Posted by graser View Post
Hi Jens
Now you have the flux and need to postprzess it. Therefore you need to integrate phi at your boundary. There is a OF-utility named patchIntegrate.
The Problem is that phi is defined as "surfaceScalarField" and patchIntegrate only integrates "volScalarField". To integrate phi you have to modify the patchIntegrate Tool to read and integrate surfaceScalarFields.
Hf
Max
I understand, but... how??
Old   November 21, 2012, 14:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by curiosity View Post
Hi all,
Well. Is there a patch named Name_of_my_Boundary in your geometry? If yes: check the case (that is a favourite). The missing phi is more of a showstopper. Without it no mass flow will be calculated ... for that timestep (assuming this calcMassFlow is the utility I wrote and published http://openfoamwiki.net/index.php/Contrib_calcMassFlow year ago and haven't maintained for a long time. But maybe there is another utility of the same name floating around)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 21, 2012, 14:18
Assistant Moderator
Bernhard Gschaider
By copying and adapting the sources of the utility.
Personally I'd do that with swak4Foam. Either by using a patchExpression-function-Object during the simulation or the funkyDoCalc-utility afterwards (swak4Foam is one of the reasons why I don't maintain calcMassFlow anymore)
Old   November 26, 2012, 06:40
Paula
I´ll try
Thanks!
Old   December 8, 2012, 05:45
Mulualem
mulfal is on a distinguished road
Dear Foamers,
I am trying to calculate the mass flow and/or the pressure force at any field or any section of the domain, which is not pre-defined patch like the inlet/outlet patch. This question has been asked back in 2009 by haghajani in this thread though it seems no one has tried to answer it or may be I couldn’t come across any other posts related to this issue
Would be great help if some one has done or modified the patchNames in order to calculate the mass flow at any section of the domain and lend me a hand on it.
Have a nice day!
mulfal is offline   Reply With Quote
Old   December 8, 2012, 06:26
Paula
Hi Mulualem,
I´m not so sure if I´m the adecuate person to help you. Anyway, I´ll try ^^
In ParaView, click Filters-->Slice and enter the coordenates of the plane you want to calculate the mass flow into the tab Properties.
Then, Filters--->Calculator and in Scalars choose U_X or U_Y depending on the direction of the mass flow you want to calculate.
Continue with: Filters--->Integrate Variables... You´ll see a chart in wich the U_X is, in fact, the mass flow in the x-direction. This is because when you apply the filter Integrate Variables, ParaView is multiplying each area of cell of the slice you´ve chosen for the variable U_X in this cell.
That´s all, hope it´s useful for you
Elham, Pravin Kadu and mizzou like this.
Old   December 8, 2012, 06:34
Mulualem
Hi Paula,
Thank you very much for your quick reply. I will definately try your method and hope it works. I am still at my desk so will come back to you if I have encountered any problem.
This means I can even calculate the pressure forces at the same faces using using the p_rgh, am I right?
Thanks a lot!
Old   December 8, 2012, 07:28
Mulualem
Hi Mulualem,
Hi Paula,
I have been trying the steps you gave me to calculate the mass flow rate and it works fine. At least I can now work out to calculate the integral of the pressure at a chosen cross-section to obtain the pressure forces at that section.
Just I have one question though, If I want to calculate the flow rate at a small section of the face area (say a sum of cells in the domain face area), is paraView capable of choosing such kind of certain cells from the total face area of the domain?
Thanks!
Mulualem
Old   December 8, 2012, 08:03
Paula
Hi Mulualem,
Happy to know It worked
I don´t know the exact answer to your new question but I think there´s a filter called Select Extract Cells or something like that. Try it as the same way you used the other filter... and let me know if it works too
Regards,
Paula
Old   December 8, 2012, 08:57
Mulualem
Hi Mulualem,
Regards,
Paula
Hi Paula,
It works great.
Steps: After slice...go to filters>ExtractCellsByRegion
In the properties tab under the intersect with list, you can choose plane if you want to cut only one side of the face and set the coordinate but if you want to cut more than one side, you can choose box and work out with the translate, rotate and scale data in order to extract the exact surface area you want.
It has been great to talk to you and you saved a lot of my time. I have been looking the codes developed for this kind of post processing jobs but now I will put them aside for the time being and post-process my data using the paraView.
Thank you and have a nice weekend!
Best Wishes,
Mulualem
Old   December 8, 2012, 11:13
Paula
Great! It´s nice having been useful
Thanks for your reply !
Good luck!
Old   March 22, 2013, 08:07
GeoKNL is on a distinguished road
Hi.
Have you finally found why was your flux oscillating?
Because i have the same problem (with steady boundary conditions).
Thanks
George
GeoKNL is offline   Reply With Quote
Old   July 1, 2013, 08:22
Default Mass flux output in a file
  #39
Hale
Hale is on a distinguished road
Is there any body who knows how to write the fluxes given by calcMassFlow in a text file and not on the terminal where it normally does?
I want to plot the values on a graph but I don't know how to write them in a file!
NB. calcMassFlow is a ultility that gives the mass flux through patches.
Thank a lot
Hale is offline   Reply With Quote
Old   July 1, 2013, 18:21
Assistant Moderator
Bernhard Gschaider
Originally Posted by Hale View Post
Thank a lot
You're talking about http://openfoamwiki.net/index.php/Contrib_calcMassFlow ? Either use a script to extract that information from the output (I use for some strange reasons PyFoam) or use swak4Foam http://openfoamwiki.net/index.php/Co...e_calcMassFlow (that does output into a file too)
Calculate Mass Flow in a faceSet during calculation torvic OpenFOAM Running, Solving & CFD 1 August 11, 2008 19:05
mass flow rate calculation Ahmed CFX 7 June 20, 2008 05:55
Calculation of mass flow rate msrinath80 OpenFOAM Running, Solving & CFD 0 April 18, 2007 14:05
Calculation of added mass in viscous flow kharati Main CFD Forum 2 February 1, 2006 00:28
Mass Flow Rate Calculation Paul FLUENT 9 March 23, 2002 08:37
