Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
FluentToFoam
Old   August 13, 2007, 20:10
Default Hi everyone, In my research
paka is on a distinguished road
Hi everyone,
In my research I had to import the previously created model from Fluent to OpenFOAM.
The Fluent model was created in 2D. After conversion to OpenFOAM the model depth in z-direction is 0.540534 (+-0.270267).
Can anyone explain why this happens? Why the uniform depth 1.0 is not assumed?
Is there any way to change that 0.54 depth to 1.0? I do not want to/cannot use Fluent at the moment, so I want to be able to do everything in OpenFOAM.
Thanks,
Krystian
paka is offline   Reply With Quote
Old   August 14, 2007, 06:53
Default Krystian, use the transfor
Tommaso Lucchini
lucchini is on a distinguished road
Krystian,
use the transformPoints utility and you will get what you need.
Regards,
Tommaso
lucchini is offline   Reply With Quote
FluentToFoam model thickness paka OpenFOAM Post-Processing 0 August 9, 2007 20:20
[Commercial meshers] Defining new faces after fluenttofoam conversion mayank OpenFOAM Meshing & Mesh Conversion 3 June 4, 2007 10:13
