August 9, 2007, 20:20 |
Hi there,
When 2D model is
Rep Power: 18 |
Hi there,
When 2D model is converted to OpenFOAM format it creates a new model in 3D anyway - that's the OpenFOAM way. Now my question. What thickness for the model is assumed? Should it be a unity or is it some unform "weird" small number? I'm asking, because I try to calculate surface forces, which I assume are calculated based on the OpenFOAM model thickness. After conversion, my present model thinckness is something between +-0.0248 or 0.248 (not sure now, do not have access to the model). Thanks, Krystian |
momentum thickness | Feitoudaer | Main CFD Forum | 0 | April 29, 2008 13:32 |
FluentToFoam | paka | OpenFOAM Post-Processing | 1 | August 14, 2007 06:53 |
[Commercial meshers] Defining new faces after fluenttofoam conversion | mayank | OpenFOAM Meshing & Mesh Conversion | 3 | June 4, 2007 10:13 |
Shell Thickness in Model | Chetan Shah | FLUENT | 1 | September 5, 2003 10:38 |
zero thickness boundaries | reza besharati | FLUENT | 2 | June 26, 2001 20:33 |
