Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
ReconstructPar
Old   March 8, 2005, 04:04
Default Hi, I have decomposed my prob
Marco Kupiainen
kupiainen is on a distinguished road
I have decomposed my problem onto 4 processors. This works fine. Solving the equations works fine also, but when I try to reconstruct I run into the following problem:
h04n05:~>reconstructPar . base -time 0.001
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.0.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : reconstructPar . base -time 0.001
Date : Mar 08 2005
Time : 09:52:58
Host : h04n05.pdc.kth.se
PID : 27978
Root : /afs/nada.kth.se/home/nada/marcok/PDC/expSonicOodles
Case : base
Nprocs : 1
Create database
Create mesh
Time = 0.001
Reconstructing FV fields
Reconstructing volScalarFields
T
Tzz
pmean
Tmean
e
muEff
rhomean
--> FOAM FATAL ERROR :
FOAM exiting
h04n05:~>
These are not the only fields I have written to file:
h04n05:~>ls base/processor0/0.001/
T Tmean Txx Tyy Tzz U Umean e k muEff nAveragingSteps.raw pmean rho rhomean time
h04n05:~>
The error message does not give much help. Please advice.
kupiainen is offline   Reply With Quote
Old   March 8, 2005, 04:10
Default Looks to me like a bug in the
Hrvoje Jasak
Looks to me like a bug in the error message + a problem with boundary conditions. Have you got any fancy b.c.-s in your case? Could you try some other case (lid-driven cavity) to see all is well with the setup and installation? Could you please list the boundary condition types in the rhomean field in the time step 0.001
In summary, looks like a foam problem and we need to investigate - any chance of getting the case?
Hrv
Hrvoje Jasak
Old   March 8, 2005, 04:57
Default I had a look at the T(temperat
Marco Kupiainen
I had a look at the T(temperature) field and it looked like where the boundary is described:
boundaryField
inlet1
type fixedValue;
value uniform 298;
outside
type zeroGradient;
wall
type zeroGradient;
base
type zeroGradient;
procBoundary0to2
type processor;
value nonuniform List<scalar>
3039
297.698
297.55
297.358
procBoundary0to1
type processor;
995
293.813
293.603
And the rho field looks like
boundaryField
inlet1
type fixedValue;
value uniform 5.82019;
outside
type pressureTransmissive;
pInf 0;
lInf 0;
1015
5.66108
5.6583
wall
type zeroGradient;
base
type zeroGradient;
procBoundary0to2
type processor;
3039
5.6822
5.61607
procBoundary0to1
type processor;
995
3.20264
3.20065
for rhomean
boundaryField
inlet1
type fixedValue;
outside
pInf 0;
lInf 0;
value uniform 1.13013;
wall
type zeroGradient;
base
type zeroGradient;
procBoundary0to2
type processor;
3039
5.02962
4.74368
procBoundary0to1
type processor;
995
2.01781
2.01751
2.01766
I don't require rho as initial data and calculate it as:
Info<< "Calculating field rho\n" << endl;
volScalarField rho
IOobject
"rho",
runTime.timeName(),
runTime,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
psi.dimensions()*p.dimensions(),
p.boundaryField().types()
rho == psi*p;
Does rho get the right processor b.c. this way?
Where do I mail the case?
Old   March 8, 2005, 05:04
Default Yup, reproduced it - the probl
Hrvoje Jasak
Yup, reproduced it - the problem is the pressure transmissive b.c. I'll fix the bug and let you know.
Apologies for inconvenience,
Hrv
Hrvoje Jasak
Old   March 8, 2005, 05:37
Default Currently the pressureTransmis
henry is on a distinguished road
Currently the pressureTransmissive BC is only implemented for p and not rho and consequently only correct for trans-sonic codes solving for p not rho. That means you should only use the pressureTransmissive BC for sonicFoam, sonicFoamAutoMotion and sonicTurbFoam not rhopSonicFoam or rhoSonicFoam. We are developing a replacement for the last two which is nearing completion but more testing is necessary before release.
henry is offline   Reply With Quote
Old   March 8, 2005, 05:40
Default What about the incomplete erro
Hrvoje Jasak
What about the incomplete error message - if I try non-existing nams for patch field types it seems to work OK. Hmm.
Hrvoje Jasak
Old   March 8, 2005, 05:50
Default I have just tried decomposing
I have just tried decomposing and reconstructing cases including pressureTransmissive BCs with OpenFOAM-1.1 and it works fine. I have added quite a bit of new BC handling to this release which will fix many (but not all) of the problems relating to pre/postprocessing tools.
1.1 is ready for release but due to the VERY large number of downloads of the current version we are having to find a new server to release from. We hope it will go out later this week.
Non-existing (not linked-in) patchField types are currently automatically handled as a default type which was introduced so that all boundary types do not have to be linked into all post-processing utilities. This has proved very effective for this purpose but has the disadvantage that if a full definition of the BC is needed by the application but it is not linked it does not know. I am working on this issue.
Old   March 8, 2005, 05:52
Default Great! Thanks Henry, Hrv
Hrvoje Jasak
Great!
Thanks Henry,
Hrv
Hrvoje Jasak
Old   August 20, 2008, 05:25
Default Hallo everyone, I simulated
Sebastian Vogl
sebastian_vogl is on a distinguished road
Hallo everyone,
I simulated the evaporation of single droplets of C7H16 in air (5 injectors inject 10 droplets each with a time difference of 1e-4 seconds). The difference between the simulated time steps is 1e-6 seconds. However I decided to reconstruct only every 10th time step, as it is detailed enough for evaluation.
The problem I have is that the development of the continuous phase (air) and of the dispersed phase (C7H16) doesn't fit together. After 100 simulated time steps the droplet was already heated up (from it's start value of 303K) by the surrounding air (from it's start value of 1500K) whereas the decrease of the air temperature doesn't follow soon but has an delay of 30 time steps in comparison to the development of the droplet temperature. That means that the droplet is heated up by the hot surrounding air but the air temperature decreases only 30 time steps later. This obviously doesn't make sense. This effect can also be seen when analysing the decreasing mass of the droplet and the increasing fuel vapour in the surrounding air.
If I reconstruct every simulated time step instead of every 10th, I don't get this problem.
The following two pictures show the decrease of the droplet mass (is denoted with "m" in the scale on the right side of the picture) and the fuel vapour in air(is denoted with "C7H16" in the scale on the right side of the picture) after 100 simulated time steps. In the first one every single time step was reconstructed. The evaporation process looks realistic. In the second one with every 10th time step reconstructed there is the mentioned delay of the fuel vapour and droplet mass decrease.
As reconstructing of every time step takes a lot of time and memory of my disc, I would like to restrict the reconstruction to only a small number of time steps (of cours without the mentioned problem from above).
Does anyone of you know why this problem arises? I would be very pleased to hear of you soon.
Thanks in advance,
Sebastian Vogl
sebastian_vogl is offline   Reply With Quote
Old   August 20, 2008, 06:01
Default I am sorry for uploading the p
Sebastian Vogl
I am sorry for uploading the pictures extra but I had to reduce the file size and I must upload them as .zip files.
t100_mTropfen_verdampfter_Kraftstoff_Umgebung_comp ressed.jpg.gz
t10_mass_droplet_evaporated_fuel_in_air_compressed .jpg.gz
Old   August 27, 2008, 12:32
Default Hallo again, I'm sorry for
  #11
Sebastian Vogl
Hallo again,
I'm sorry for begging again, but my problem is very serious.
Please take the time and think about it.
Sincerely,
Sebastian Vogl
Old   April 20, 2009, 12:05
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Good Evening,
My reconstructPar collapsed suddenly! What happened! I did nothing!
A few minute ago, it works very well!
Here's error messages....help, please!
lamb@lamb:~/OpenFOAM/lamb-1.5/run/tutorials/oodles/plate5000A6> reconstructPar -latestTime
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : reconstructPar -latestTime
Date   : Apr 20 2009
Time   : 23:25:45
Host   : lamb
PID    : 6163
Case   : /home/lamb/OpenFOAM/lamb-1.5/run/tutorials/oodles/plate5000A6
nProcs : 1
Create time
Create mesh for time = 35
Time = 45.6
        pPrime2Mean
attempt to access element from zero sized list#0  Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/printStack.C:203
#1  Foam::error::abort() at ~/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/error.C:242
#2  Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/errorManip.H:87
#3  Foam::UList<double>::checkIndex(int) const at ~/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/UListI.H:96
#4  Foam::UList<double>::operator[](int) at ~/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/UListI.H:118
#5  Foam::Field<double>::rmap(Foam::UList<double> const&, Foam::List<int> const&) at ~/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C:468
#6  Foam::fvPatchField<double>::rmap(Foam::fvPatchField<double> const&, Foam::List<int> const&) at ~/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvPatchField.C:211
#7  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvFieldReconstructor::reconstructFvVolumeField<double>(Foam::IOobject const&) at ~/OpenFOAM/OpenFOAM-1.5/applications/utilities/parallelProcessing/reconstructPar/fvFieldReconstructorReconstructFields.C:138
#8  void Foam::fvFieldReconstructor::reconstructFvVolumeFields<double>(Foam::IOobjectList const&) at ~/OpenFOAM/OpenFOAM-1.5/applications/utilities/parallelProcessing/reconstructPar/fvFieldReconstructorReconstructFields.C:480
#9  main at ~/OpenFOAM/OpenFOAM-1.5/applications/utilities/parallelProcessing/reconstructPar/reconstructPar.C:188
#10  __libc_start_main in "/lib/libc.so.6"
#11  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
    From function UList<T>::checkIndex(const label)
    in file /home/lamb/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/UListI.H at line 96.
FOAM aborting
Aborted
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   April 21, 2009, 01:47
lakeat's Avatar
Daniel WEI (老魏)
Mea culpa, I delete the "1e-5" directory which contains the non-zero boundary file. I apologize.
Daniel WEI
Beijing, China
Email
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
[mesh manipulation] Error with reconstructPar skabilan OpenFOAM Meshing & Mesh Conversion 3 June 10, 2008 18:34
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 04:23
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
ReconstructPar error r2d2 OpenFOAM Pre-Processing 7 September 12, 2006 09:37
