on-the-fly post-processing?
Old   December 10, 2010, 03:56
Default on-the-fly post-processing?
Aljaz Osterman
aljaz is on a distinguished road
Hi!
I'm trying to figure out how to visualize the results from OpenFoam while the simulation is still running. I'm using OF 1.7.1 and ParaView 3.8. Perhaps post-processing is not the best term here as what I'd like to see is actually something done simultaneously.
I'd like to see the results for example as contour plots or vector fields or as a plot of a single variable (depends on a case).
I read in OpenFOAM release notes for version 1.7.0 that "Post-processing has been extended particularly to function objects, the on-the-fly post-processing system."
I'd be very glad if somebody can point in which direction I should take a look.
Btw, I've come across a term "in-situ visualization". As I understood, the point is to dump redundant data and keep only visualization results. Am I correct about this or it's the same thing as on-the-fly visualization?
Best regards!
aljaz is offline   Reply With Quote
Old   December 11, 2010, 02:30
Alberto Passalacqua
Originally Posted by aljaz View Post
Hi!
Open the case in paraFoam. When data are stored, you will be able to load them using the "refresh times" button.
Function objects compute averages, forces, sample data and store them as separate files. You can see various examples in the tutorials.
Best,
Alberto Passalacqua
Old   December 13, 2010, 01:37
Aljaz Osterman
Thank you Alberto. I'm well aware of these options.
If I make myself clearer, is there a way to visualize data "directly" without saving them first?
Regards!
Old   December 13, 2010, 03:10
matej forman
matejfor is on a distinguished road
Well it depends what data you want to visualize.
The only way to visualize the data without saving is to pipe them into the visualization software. I have not done it myself but I would make a version of write to writeOnFly which would send the data to gnuplot, or parafoam maybe through some python interface so you have only window with the results. This would slow down the calculation with the visualization step. Maybe faster would be to write down the data, show them and remove.
But there must be someone more clever in these things than me, I hope.
good luck
matej
matejfor is offline   Reply With Quote
Old   December 13, 2010, 14:18
Fabian Braennstroem
braennstroem is on a distinguished road
the co-processing feature of paraview is the right approach I assume:
http://www.paraview.org/Wiki/CoProcessing
http://www.kitware.com/blog/home/post/28
With visit it should be possible as well:
http://visitusers.org/index.php?titl...torial-in-situ
http://visitusers.org/index.php?titl...anual_Examples
https://wci.llnl.gov/codes/visit/2.0...VisIt2.0.0.pdf
Best Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   December 14, 2010, 06:49
Aljaz Osterman
Thanks!
At a first glance, I think this is what I've been looking for.
With best regards!
Old   April 24, 2014, 05:05
gigilentini8 is on a distinguished road
anyone succeeded in using OF with co-processing?
I think it's a interesting topic with great potential...
gigilentini8 is offline   Reply With Quote
Old   July 13, 2016, 22:03
Srinivas
bolem is on a distinguished road
any updates on this topic of using OpenFoam with co-processing please..
bolem is offline   Reply With Quote
Old   July 20, 2016, 08:18
Post
RomainBou is on a distinguished road
maybe you should read the following tutorial using OF 3.0.X :
http://www.dicat.unige.it/guerrero/o...ng/module4.pdf
(more tutorials here :
http://www.dicat.unige.it/guerrero/O...016summer.html)
RomainBou is offline   Reply With Quote
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Question about post processing qtian OpenFOAM Post-Processing 0 July 24, 2007 12:44
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
