[OpenFOAM] Contour maps of integrated values
Old   March 29, 2011, 16:09
Default Contour maps of integrated values
jeff osborne
ozzythewise is on a distinguished road
Hello all,
I need to create a contour plot in paraview of a nondimensional temperature field in a channel with a fixedgradient boundary condition. The way I'm nondimensionalizing it is as follows:
phi = (T - Tw) / ( (Tb - Tw)
Where
T = local temperature
Tw = Temperature at the wall. This can be any temperature value at any point on the wall actually, just so long as it is consistent
Tb = Some bulk temperature which is calculated as follows:
Tb = integral (u T dA_inlet) / U Ainlet
where:
u = local x-velocity
dA_inlet = over the inlet area
U = bulk velocity = 1
Ainlet = inlet area = 8
So, somehow I need paraview to calculate these at each time step for me and then I can make a contour plot of it and also an animation. The issue is with trying to calculate Tb for each time step because it isn't constant, it changes over time. I can do it for one time step by using the integrator filter in paraview, but I would like a way for paraview to do it for all time steps that way i can just be make a contour map of phi(t) (read, phi as a function of t).
Anyone know how I can go about doing this?
Thanks
jeff
ozzythewise is offline   Reply With Quote
[General] label contour values in paraview sehs15 ParaView 9 January 19, 2021 04:31
Set cell volume integrated field values to preserve integral Diro7 OpenFOAM Pre-Processing 2 June 3, 2018 10:44
Periodic (rotational)flow: a bit of confusion concerning reference values Mr.Goodcat FLUENT 0 March 22, 2016 07:31
k-w SST freestream values for w hazari.aaquib Main CFD Forum 4 March 18, 2016 04:29
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
