Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Tecplot360 problem for reading OpenFOAM data
Old   July 21, 2010, 12:48
Lightbulb Tecplot360 problem for reading OpenFOAM data
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
Using foamToTecplot360, all time steps data converts to plt files. but after opening tecplot software and reading plt files an error says which grid should be import first. by importing boundrymesh files first also the error is same as before.
How can i use Tecplot360 for reading OpenFOAM data?
maysmech is offline   Reply With Quote
Old   July 28, 2010, 15:20
maysmech's Avatar
Any suggestion?
Old   August 4, 2010, 19:54
Naveen
vetnav is on a distinguished road
I am also running into the same problem, anyone who knows what are the steps to follow to read these .plt files and see the results using Tecplot360.
Thanks
vetnav is offline   Reply With Quote
Old   August 5, 2010, 20:53
Naveen
Hi maysam,
Initially I too faced the same problem, but I found what was the mistake. When you used foamToTecplot360 u will see that there are *.plt files for each time and then there is also a *_grid.plt.
So when you use Tecplot360, go to load data files and then click multiple files, first select the *_grid.plt and click on add file after this select the *.plt file which u want to plot.
It worked well for me, hope it will work for u also
Naveen
Old   August 6, 2010, 01:49
Smile Thanks
maysmech's Avatar
It works for me too.
Thank you very much Dear Naveen.
Old   April 13, 2011, 15:37
ya
rujia is on a distinguished road
hi everyone:
after I converted the result data to tecplot. the directory name is specified Tecplot360.In Tecplot360,there are some files
1 *_grid.plt, only one file (it need be load in tecplot360 firstly)
2 *.plt file as the results for each time step(add these file after the grid file)
3 and in boundarymash directory ,there are some mesh files for each time step. (how about this part?)
For the third part-mesh data- is not useful? Dose anybody konw this?
rujia is offline   Reply With Quote
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 02:00
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 11:32
IFStream read float point data problem liu OpenFOAM Running, Solving & CFD 0 October 24, 2008 12:14
Can I use OpenFOAM to solve unsteady diffusion problem yongshenglian OpenFOAM Running, Solving & CFD 1 September 17, 2008 12:03
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
