May 17, 2012, 14:21 |
problem in toposet
Hi Foamers,
i'm trying to run chtMultiRegionFoam on my own case, it's a tube with outer diameter 11cm, inner diameter 10cm and length 100cm i created a cylinder in blockMesh file with outer diameter 11cm and length 100 cm asin this code Code:
convertToMeters 0.01; vertices ( (0 0 0) // point 0 (0 11 0) // point 01 (0 16.5 1.47372) // point 02 (0 20.52628 5.5) // point 03 (0 22 11) // point 04 (0 20.52628 16.5) // point 05 (0 16.5 20.52628)// point 06 (0 11 22) // point 07 (0 5.5 20.52628)// point 08 (0 1.47372 16.5) // point 09 (0 0 11) // point 10 (0 1.47372 5.5) // point 11 (0 5.5 1.47372) // point 12 (100 11 0) // point 13 (100 16.5 1.47372) // point 14 (100 20.52628 5.5) // point 15 (100 22 11) // point 16 (100 20.52628 16.5) // point 17 (100 16.5 20.52628)// point 18 (100 11 22) // point 19 (100 5.5 20.52628)// point 20 (100 1.47372 16.5) // point 21 (100 0 11) // point 22 (100 1.47372 5.5) // point 23 (100 5.5 1.47372) // point 24 (0 11 11) // point 25 (100 11 11) // point 26 ); blocks ( hex (25 1 3 25 26 13 15 26) (10 10 10) simpleGrading (1 1 1) hex (25 3 5 25 26 15 17 26) (10 10 10) simpleGrading (1 1 1) hex (25 5 7 25 26 17 19 26) (10 10 10) simpleGrading (1 1 1) hex (25 7 9 25 26 19 21 26) (10 10 10) simpleGrading (1 1 1) hex (25 9 11 25 26 21 23 26) (10 10 10) simpleGrading (1 1 1) hex (25 11 1 25 26 23 13 26) (10 10 10) simpleGrading (1 1 1) ); edges ( arc 1 3 (0 16.5 1.47372) arc 3 5 (0 22 11) arc 5 7 (0 16.5 20.52628) arc 7 9 (0 5.5 20.52628) arc 9 11 (0 0 11) arc 11 1 (0 5.5 1.47372) arc 13 15 (100 16.5 1.47372) arc 15 17 (100 22 11) arc 17 19 (100 16.5 20.52628) arc 19 21 (100 5.5 20.52628) arc 21 23 (100 0 11) arc 23 13 (100 5.5 1.47372) ); boundary ( outerface { type wall; faces ( (1 13 15 3) (3 15 17 5) (5 17 19 7) (7 19 21 9) (9 21 23 11) (11 23 13 1) ); } inlet { type wall; faces ( (25 1 3 25) (25 3 5 25) (25 5 7 25) (25 7 9 25) (25 9 11 25) (25 11 1 25) ); } outlet { type wall; faces ( (26 15 13 26) (26 17 15 26) (26 19 17 26) (26 21 19 26) (26 23 21 26) (26 13 23 26) ); } ); mergePatchPairs ( ); Code:
actions ( // flow inside the tube { name flow; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0 11 11); // start point on cylinder axis// p2 (100 11 11); // end point on cylinder axis// radius 10.0; } } { name flow; type cellZoneSet; action new; source setToCellZone; sourceInfo { set flow; // name of cellSet } } //tube { name tube; type cellZoneSet; action clear; } { name tube; type cellSet; action add; source cellToCell; sourceInfo { set flow; } } { name tube; type cellSet; action invert; } { name tube; type cellZoneSet; action new; source setToCellZone; sourceInfo { set tube; } } ); Code:
Create time Create polyMesh for time = 0 Reading topoSetDict Time = 0 mesh not changed. Created set flow Applying source cylinderToCell Adding cells with centre within cylinder, with p1 = (0 11 11), p2 = (100 11 11) and radius = 10 Set flow now size 0 Created set flow Applying source setToCellZone Adding all cells from cellSet flow ... Set flow now size 0 Created set tube Clearing set Set tube now size 0 Read set tube with size 0 Applying source cellToCell Adding all elements of cellSet flow ... Set tube now size 0 Read set tube with size 0 Inverting set Set tube now size 6000 Created set tube Applying source setToCellZone Adding all cells from cellSet tube ... Set tube now size 6000 End Code:
Create time Create mesh for time = 0 Creating single patch per inter-region interface. Trying to match regions to existing cell zones. Number of regions:1 Writing region per cell file (for manual decomposition) to "/home/khattab/ahmed.2.0.1/tutorials/heatTransfer/chtMultiRegionFoam/Graetz10/constant/cellToRegion" Writing region per cell as volScalarField to "/home/khattab/ahmed.2.0.1/tutorials/heatTransfer/chtMultiRegionFoam/Graetz10/0/cellToRegion" Region Cells ------ ----- 0 6000 Region Zone Name ------ ---- ---- 0 1 tube Sizes of interfaces between regions: Interface Region Region Faces --------- ------ ------ ----- Reading volScalarField Y_char Reading volScalarField cellToRegion Reading volScalarField p Reading volScalarField T Reading volScalarField k Reading volScalarField epsilon Reading volScalarField P_rgh Reading volScalarField Y_pmma Reading volVectorField U Only one region. Doing nothing. End |
May 28, 2012, 04:18 |
Dears,
finally i have found the problem. in blockMeshDict i have converted units to centimeter so i have wrote 0.1m as 10. in toposet i used same value but it red it as meters so 10 became 10m. it red only tube region because it was invert of other region which had been red as empty. as assigned all cells for tube region. now every thing is do well. thanks for all who red this post. ahmed |
May 28, 2012, 05:56 |
cfdkid
Rep Power: 17 |
What does topoSet do ?
________________________________________ Regards, CFDkid It never gets easier You just get Better |
May 28, 2012, 11:44 |
Dear Kid,
topoSet is used to split your mesh into many regions so you can give properties to the entire region not only for patches. i used for the first time for heat transfer problem in chtMultiRegioFoam solver with multiRegionHeater case. you can try the case and will get a good experience of it. if any question don't hesitate to post for me. good luck |
May 28, 2012, 16:08 |
Andrew Kettner
Rep Power: 13 |
New to OpenFoam and I am attempting post process the results from the the chtMultiRegionFoam tutorials. I cannot seem to get paraview to read any of the files. If I attempt to look at the with a gedit the file does not load correctly and I get nonsense. This has not been a problem for other tutorials. I am running open foam on a virtually install Ubuntu 12.04.
Suggestions please Thanks |
May 29, 2012, 05:50 |
#6 | |
i experienced same problem before, after processing chtMultiRegionFoam solver, as usual type paraFoam and paraview will open then from toolbar choose file then open, it will open window for you shows the directory of your case choose the five files with .openfoam extension (bottomair topair heater rightssolid leftsolid), click apply. now you can see results. the problem with gedit is that results are written in binary so you can't see it correctly. if you want go to controlDict file in system directory then change ninary to Ascii code then you will see results correctly. good luck |
May 29, 2012, 16:28 |
Andrew Kettner
Rep Power: 13 |
Thx
Ahmed That did it. |
June 7, 2012, 07:19 |
#9 |
Rehan amin
Rep Power: 13 |
Hello sir,
1)can you please tell me the significance of 'invert' action? also 2) what does 'type cellset' & 'type cellzoneset' mean? |
June 7, 2012, 12:21 |
#10 | |
1- invert is used to specify region which is the rest of the domain instead of specify it as every region you can just say that it is the invert of all regions in the domain. 2- about this question give me more time to get a detailed answer for you. |
March 24, 2013, 15:18 |
#11 |
Meinan Chen
Rep Power: 13 |
Hi ~~ I wonder do you still work on chtMultiRegionFoam? cuz I see that the time you replied is really long time ago, I am totally new to OPenFoam, and now I am trying to split the region into solid and fluid. I generated my mesh in ICEM, and converted it in Openfoam, and now I am trying to split the region, I try to define the region in MakeCellSets file, I wonder am I doing right? Should I split the region in MakeCellSets or topoSet? I feel so confused, really hope that you can reply me! THanks!!!
October 29, 2015, 08:26 |
#12 |
Mahdi
Rep Power: 13 |
Hi all
I am building a test case with 2 main regions (1 solid and 1 fluid attached together). I built it simply by using topoSet. My question is if I wanna create a wallFilmRegion between these two regions, how can I address the source info for that? I mean what it the correct source info for this patch? If you look at the case "tutorail/lagrangian/reactingParcelFilmFoam/rivuletpanel", the wallFilmRegion is created using a source from blockMeshDict. { name wallFilm; type faceSet; action new; source patchToFace; sourceInfo { name filmWalls; } } { name wallFilm; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet wallFilmFaces; } } But in my case the connecting patch between solid region and fluid region is not defined in advance and should be created within the topoSet itself! (First by topoSet I define 2 regions and now I wanna address the patch in between as source for wallFilmRegion.) any idea for that!? |
December 10, 2016, 10:56 |
topoSetDict
#13 |
AliReza
Rep Power: 9 |
Hi
How can be defined for a triangular box? |
September 7, 2017, 06:17 |
#14 |
Umer
Rep Power: 9 |
September 18, 2017, 13:08 |
topoSet in inclined box
#15 |
karundev
Rep Power: 8 |
Hello all,
How can I define an inclined cell zone (a rectangular box inclined at an angle), as boxToCell gives horizontal Thank you |
September 18, 2017, 22:42 |
#16 |
according to this https://openfoamwiki.net/index.php/TopoSet you could use Code:
surfaceToCell Code:
setToCellZone In any case the problem is that you have to get to a mesh with cells not intersecating your stl surface or you won't get a smooth and plained "surface" at your cellZone. Regards. |
October 26, 2017, 06:29 |
Usage of topoSetDict
#17 |
Anil Kumar
Can any one help me in understanding, how the topoSetDict is functioning and what exactly is box defines. Will this box collects all the information from the cells ? |
November 1, 2017, 02:20 |
creating square patch (for air inlet) on the bottom face using cellset in toposet
#18 | |
Rep Power: 13 |
Hi all,
I am trying to feed air through a square inlet on the bottom face of a 3D rectangular tank filled with water. I am able to do this using faceset in toposet dict as follows: { name faceGrabbed; type faceSet; action new; source boxToFace; sourceInfo { box (0.035 0.035 0.08)(0.04 0.04 0.08); } } But when i tried to do it with cellset (by replacing the type with cellset) as given below in toposet dict then I am facing the following error: unexpected class name cellset expected faceset while reading object faceGrabbed. { name faceGrabbed; type cellSet; action new; source boxToCell; sourceInfo { box (0.015 0.015 0)(0.02 0.02 0); } } ) My create patch dictionary is as follows: { //- name of new patch name bubble; //- type of new patch patchInfo { type patch; } //- How to construct: either from 'patches' or 'set' constructFrom set; //- if constructionFrom = set : name of faceSet set faceGrabbed; } ); I am running the following commands: blockMesh TopoSet CreatePatchDict -overwrite -------here I am getting error: Foam fatal IO error: unexpected class name cellset expected faceset while reading object faceGrabbed. Can anyone please help as I tried a lot to retrieve this. Quote:
November 1, 2017, 23:50 |
#19 | ||
From your topoSetDict:
Maybe you should define a faceSet into your topoSet... |
November 2, 2017, 00:21 |
#20 |
Rajesh
Rep Power: 8 |
Yes, I did it with faceset. But I want to try the same with cellset also. The reason for using cellset is to create circular patch in future instead of square patch as mentioned above. As far as I know, we can only create circular patch using cellset.
So I want to know how can i do it with cellset in toposet. Thanks for your reply. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
