May 21, 2012, 05:31 |
Select cells based on fields
Dragos
Rep Power: 20 |
I'm trying to select a set of cells based on their velocity magnitude. In the old days there was an utility called fieldToCellSet, then cellSet, but now only setSet. Could anyone clue me how to use it to select a set of cells based on their velocity magnitude? Thanks, Dragos |
May 21, 2012, 08:15 |
setSet
Dragos
Rep Power: 20 |
The answer seems to be:
setSet >cellSet bubu new >cellSet bubu add fieldToCell U 50 150 >quit Now, there is a cell set with all the cells having the velocity magnitude in the range [50;150] |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Fluent: Mesh Adaption based on Gradient | enigma | FLUENT | 4 | July 15, 2010 17:36 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
Number of cells | Christian Holm | Main CFD Forum | 8 | February 20, 2002 07:37 |
