August 3, 2012, 09:20 |
mapFields producing "nan" entry
#1 | |
Tyler Landfried
Rep Power: 15 |
Morning all,
Sorry, this is a repost, I posted this in the Mesh Utilities forum sometime early last week and haven't received any responses. I thought perhaps this is a better forum to post it, where it might be seen. Anyhow, on to my problem. I've run into a requiring problem that I can't seem to fix. So, I thought I'd bring the problem here and see if anyone has some familiarity with it or any insight. Additionally, I've posted the problem on collab.pitt.edu. The problem I'm having involves using the mapFields utility on a supercomputing cluster, SAM at Pitt. When I run locally, the utility has no problems. However, when I run on the cluster, the utility likes to create "nan" entries in the pressure fields. The problem then being, when I run my solver, simpleFoam in my case, errors occur when the first "nan" entry is encountered. I get the error: Quote:
From what I've been able to gather, the reason I only have this problem on the cluster could be due to a discrepancy between the $FOAM_SETNAN entry I have locally and on the cluster, however, when I checked the setting on both, they were the same. As of this point, I am unsure what exactly I should do. I have previously just run mapFields locally and then uploaded the newly initialized time to SAM. However, this isn't a convenient way to do it, and will be extremely time consuming in the future when I have larger, more intensive simulations. Any help or suggestions? -Tyler Last edited by tlandfried; August 3, 2012 at 14:55. |
August 7, 2012, 07:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Tyler,
OK, a few questions:
Bruno
August 7, 2012, 10:02 |
Tyler Landfried
Rep Power: 15 |
Morning Bruno,
Thanks for the reply. Sorry for the poor first post, you are right about a few things. First to answer your questions. 1. I run 2.1.0 locally, and 2.1.x on the cluster. 2. Sorry, not totally sure if I'm answering this fully but: Code:
#(these two just load the openFoam module for me) module load openfoam/2.1.x-double-gcc45 . $OPENFOAM_RC blockMesh mapFields ../R08_A2000_080/ -consistent 3. You are right, I meant to say that FOAM_SETNAN is unset. You are correct, and as you'd expect Code:
export | grep FOAM_SETNAN 4. I do have a case, but its pretty large. As in, when compressed, the initialization and the actual test case are over a gig. I can make a simpler version, but am not sure if it will reproduce the error correctly, as I'm only seeing it when extrapolating to larger domains, or large number of elements. Let me think about this some more, as to how I could make a small example. I do have a possible idea, the more that I'm thinking about the possible problems. So, since like you made clear, the issue is an operation actually producing the "nan" entry. What I'm doing, is taking a standard geometry, a round jet issuing axially into a round pipe, and changing the size of the confinement pipe. So what I was trying to do, was initialize my simulation using results from a different confinement pipe case. And this seemed to work well, until I tried to do it for large meshes. Which, I suppose the issue is either the increased number of elements or perhaps the increased domain size (due to large diameter)? Final thought, as I examine in much more detail when the "nan" entries occur, the values around it are very small, 10^(-300), or basically zero. This seems extremely low when considering machine precision. Last edited by tlandfried; August 7, 2012 at 12:18. |
August 7, 2012, 10:39 |
#4 | |
Bruno Santos
Rep Power: 128 |
Mmm... there is a rather big difference between 2.1.0 and 2.1.x. You might have gotten a commit from 2.1.x that was midway of a bug fix or an accidental bug might have been introduced. In the log of the applications you run on the cluster, you can see the version and commit hash number for the 2.1.x version you're using.
The simplest diagnosis might be the following steps:
August 7, 2012, 10:44 |
Bruno Santos
Rep Power: 128 |
In case this doesn't do the trick, then creating a variant of this tutorial might be the best way to go: compressible/rhoCentralFoam/LadenburgJet60psi
August 7, 2012, 12:18 |
Tyler Landfried
Rep Power: 15 |
Hm.. oddly enough when I check for the git commit hash it only says '2.1.x'
So.. I'm looking into this some more and will post when I know more. EDIT: So on the server and my local machine, I've tried 2.1.1, and an old git repository of 2.1.x. However, when reviewing the results, the "nan" entry only shows up on the supercomputer. Suggesting this is something involved with the settings that are different between the two. What possibly could be causing this? I know were using two different compilers, gcc44 locally, gcc45 on the server. Possible? Not sure about this. Last edited by tlandfried; August 14, 2012 at 21:55. |
August 20, 2012, 10:35 |
Tyler Landfried
Rep Power: 15 |
Hey all,
So just looking for more ideas as to what operation may be causing this problem on the cluster, but not locally. I tried GCC-4.4.4 and GCC 4.5.1, but still had the same issue where mapFields is creating "nan" entries in my pressure field. Any ideas? -Tyler |
August 20, 2012, 16:37 |
Bruno Santos
Rep Power: 128 |
Hi Tyler,
I think I've forgotten to ask this before, but what operating system and architecture is your cluster using? Because that might influence how OpenFOAM is built, leading to these differences! Additionally, are you able to create a simple test case, for example one based on the tutorial "compressible/rhoCentralFoam/LadenburgJet60psi"? This way it would be easier to diagnose the issue. Best regards, Bruno
Issues with mapFields | BlackBoatNavArch | OpenFOAM Pre-Processing | 38 | May 28, 2021 16:29 |
implementation of mapFields into parallel transient case | simpomann | OpenFOAM Pre-Processing | 4 | August 2, 2016 04:41 |
mapFields producing "nan" entry | tlandfried | OpenFOAM Pre-Processing | 2 | August 7, 2012 07:40 |
transientSimpleDyMFoam, mapFields and decomposePar | pad | OpenFOAM Running, Solving & CFD | 0 | December 3, 2010 05:22 |
add entry to wordList | peterwy | OpenFOAM Programming & Development | 3 | October 4, 2010 07:13 |
