BC's problem
Old   September 23, 2020, 12:38
Default BC's problem
andrea chianese
Joffy is on a distinguished road
Hi everyone,
I am a new member and i have a problem with the BC setting.
I'll try to explain my situation:
this is a stationary - laminar simulation performed on an airbox. this geometry contains 2 inlets and 4 outlets.
the purpose of the simulation is to obtain the pressure value at the outlets.
My BC setting is this:
Inlet:
p:
type totalPressure;
p0 uniform 84452.32;
U:
type zeroGradient;
Outlet:
p:
type zeroGradient;
U:
type flowRateOutletVelocity;
massFlowRate constant 0.0402778;
rhoOutlet 1.1841;
with this setting I have a "timestep continuity error" problem. this value increases with each timespet.
does anyone know if the bc setting is correct?
P.S.
- The same simulation done with starccm+ reported me about the backflow to the inlet.
- the mesh was done with HappyHexMesh and checkMesh told me that it's all ok.
- sorry for my bad english
Joffy is offline   Reply With Quote
Problem with rotating and non rotating bc's in SRFSimpleFoam and MRFSimpleFoam jcespada OpenFOAM Running, Solving & CFD 2 May 13, 2015 10:39
[Commercial meshers] Problem with cyclic BC's using Pointwise (non-orthogonality error!) Dan1788 OpenFOAM Meshing & Mesh Conversion 1 November 17, 2014 15:23
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
problem in setting up BC's san FLUENT 0 April 26, 2006 01:34
