Non-uniform Boundary Conditions
Like Tree21Likes
Old   March 9, 2013, 16:20
Default Non-uniform Boundary Conditions
Amir Abbas Aliabadi
amir.a.aliabadi is on a distinguished road
Hello There,
I am new to OpenFoam, modelling natural air convection in an enclosed box. A few walls in my boundaries have non-uniform temperatures. I like to impose a boundary condition with a temperature profile as a function of height on my walls (e.g. T=2*z+298 [K]). How do I changed the T boundary condition file for this purpose? Do I need to add any other files in any directories that this problem is set up?
amir.a.aliabadi is offline   Reply With Quote
Old   March 12, 2013, 13:40
SV
Soheyl is on a distinguished road
AAA,
If you are using OF 2.0+, take a look at codedFixedValue BC. If you are using older versions, or want more flexibility, search for swak4Foam.
Good luck and Tarif kon!
Soheyl is offline   Reply With Quote
Old   March 12, 2013, 14:47
Amir Abbas Aliabadi
Thank You Soheil,
I found many such header and C files codedFixedValue*.* under openfoam sub directories. Can you recommend which files, exactly, have to be modified? and do you have an example code that modifies fixed value boundary conditions?
Thanks,
aaa
Old   March 12, 2013, 16:06
SV
You only need to modify your BC files, i.e. 0/T. Take a look at tutorials/incompressible/simpleFoam/pipeCyclic/0.org/U to get an idea, and also search for codedFixedValue in this forum. It is not the most user-friendly syntax, but you should be able to get it working.
Old   March 12, 2013, 18:14
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
As another suggestion, maybe you would want to look into the utility funkSetBoundaryField or groovyBC that is part of the tool set "swiss army knife for foam" (a.k.a. swak4Foam).
chegdan is offline   Reply With Quote
Old   March 14, 2013, 17:27
Amir Abbas Aliabadi
Hello FOAMers,
After much investigation, I was finally able to implement codedFixedValue boundary condition for my problem. I decided to provide a "how to" instruction so others can benefit from my experience. Such examples are lacking in the OpenFOAM documentation as well as online forums, so hopefully more complete examples will emerge.
The most recent versions of OpenFOAM (2.x.x and later) are able to construct, on-the-fly, new boundary conditions (e.g. codedFixedValueFvPatchField which is derived from fixedValueFvPatchField). This is very useful since you only need to make changes to your boundary condition file (e.g. 0/T for temperature). This saves some trouble so you don't have to install third party packages like Swak4Foam or GroovyBC which at times are incompatible with your version of OpenFOAM.
Step 1: codedFixedValue boundary condition method attempts to load a shared library using case-supplied C++ code, so you need to allow your FOAM to execute user written code. You should switch "allowSystemOperations" in .../etc/controlDict from "0" to "1". So edit controlDict before proceeding to the next step. (e.g. sudo gedit /opt/openfoam211/etc/controlDict if OpenFOAM is installed under root directory)
Step 2: modify the boundary condition file (e.g. 0/T for temperature) and supply as many patches with source code as you need. An example is provided below:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 253;
boundaryField
leftWindow
type codedFixedValue;
value $internalField;
redirectType leftWindowBC;
code
vector dir=vector(0,0,1);
scalarField var=patch().Cf()&dir;
scalarField value=var*40+245;
operator==(value);
rightWindow
redirectType rightWindowBC;
code
scalarField value=var*40+250;
operator==(value);
insulation
type zeroGradient;
In the above example the temperature profiles on vertical windows are evaluated as T=40z+245 [K] for left window and T=40z+250 [K] on right window. "type codedFixedValue" is essential to define so the compiler understands what to do with the code. "value $internalField" deserves a little explanation. Although you are calculating the boundary value using the code, you need this specified so the compiler at least has a starting value to work with (e.g. when plotting boundary values using paraView at time 0). In this case the "uniform 253" value is substituted for the very start. But for later times the code is used to evaluate the boundary. "redirectType leftWindowBC" assigns a name for this boundary patch. It is absolutely critical you use a different name for each new boundary patch definition. The "code #{ ... #}" part is just C++ language and you have to make sure the code is consistent with the libraries you want to load it on. Take a look at examples elsewhere or the libraries themselves to ensure your code is compatible.
Step 3: call your desired solver in the case directory (e.g. buoyantBoussinesqPimpleFoam). The solver automatically compiles coded boundaries and creates a folder called "dynamicCode". If you examine the contents, you see for each boundary patch that you defined, there is a folder with the same assigned name and all the required *.C, *.H, and other files necessary. If your custom code is not consistent with the OpenFOAM libraries, then you get an error message why. Then the solver iterations automatically begin.
Note: it is absolutely important that you are comfortable with coding a patch that the OpenFOAM libraries understand. Otherwise you are in trouble!
Good Luck and thanks to everyone who contributed to this post!
Old   January 30, 2014, 10:27
Alejandro
ancolli is on a distinguished road
Sorry. I am new in openFoam. Your example is not working for mi. I have obtained the following error: FOAM FATAL IO ERROR: Cannot find patchField entry for...
Could you please post your entire code?. Thank you very much
ancolli is offline   Reply With Quote
Old   January 30, 2014, 18:31
Amir Abbas Aliabadi
Hi Ancolli,
It has been a long time since I used OpenFOAM and I do not have it on my current system to provide the entire case directory. I suggest you follow my previous instructions carefully, especially the beginning 2 steps. Also make sure your version of OpenFOAM supports codedFixedValue boundary conditions.
I hope this helps!
aaa
Old   February 4, 2014, 12:21
ajnewman is on a distinguished road
When you use this approach, should the boundary be specified as leftWindow or leftWindowBC in the blockMeshDict file?
Thanks!
ajnewman is offline   Reply With Quote
Old   February 4, 2014, 16:59
Also, to make the code run properly I believe there needs to be a ; after #} i.e.
Old   February 4, 2014, 18:52
Amir Abbas Aliabadi
As far as I remember both leftWindow or leftWindowBC are just names and not C++ programming syntax, so as long as you are consistent to use the same name in the linked files you should be fine. As far as syntax, be my guest, it has been a long time since I did any C++ programming
Cheers
aaa
Old   March 19, 2014, 02:32
Default hi
  #12
lynzhung
lynzhung is on a distinguished road
I am a new too and face the similar error as you .did you solve the problem ?
Thanks
Lyn
lynzhung is offline   Reply With Quote
Old   March 19, 2014, 07:02
Alejandro
Thanks
Lyn
yes, but I do not remember. Searching on my folder I have found a slightly different problem. With only one boundary condition with variable Temperature. It works!.
FoamFile
version 2.0;
format ascii;
location "0"; //nuevo//
object T;
boundaryField
inlet
type fixedValue;
value uniform 253;
outlet
type zeroGradient;
upperWall
type zeroGradient;
lowerWall
redirectType lowerWallBC;
code
vector dir=vector(1,0,0);
operator==(value);
frontAndBack
type empty;
Old   March 19, 2014, 21:53
lynzhung
FoamFile
version 2.0;
format ascii;
object T;
boundaryField
inlet
type fixedValue;
value uniform 253;
outlet
type zeroGradient;
upperWall
type zeroGradient;
lowerWall
code
operator==(value);
frontAndBack
type empty;
Thank you for your replying .I can not find any different between your code and mine.And it does not work.
Maybe the trouble is not from the code .Anything else setting should I make ?
Best wishes
lyn
Old   June 6, 2014, 21:28
J.-H. Wang
f0208secretx is on a distinguished road
Hello all,
I am running icoFoam on flow over cylinder at Re=120 case and am expecting Karman vortex street. I need a inlet velocity perturbation of any kind to trigger the onset of this shedding event. OpenFOAM 2.3 is used.
I've been trying to implement the linear profile on my inlet velocity boundary conditions but so far no luck. I simply followed the steps and change the initial 0/U file to:
  inlet
      redirectType   inletBC;
      code #{
                scalarField value=var*10+10;
                operator==(value);
During decomposePar I got the following error:
Using dynamicCode for patch inlet on field U at line 19 in "/tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/0/U.boundaryField.inlet"
Creating new library in "dynamicCode/inletBC/platforms/linux64Gcc48DPOpt/lib/libinletBC_a19a66754309cd299efbab21ef5acdb0b4c99e71.so"
Invoking "wmake -s libso /tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/dynamicCode/inletBC"
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file fixedValueFvPatchFieldTemplate.C
/tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/0/U.boundaryField.inlet: In member function ‘virtual void Foam::inletBCFixedValueFvPatchVectorField::updateCoeffs()’:
/tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/0/U.boundaryField.inlet:31:19: error: no matching function for call to ‘Foam::inletBCFixedValueFvPatchVectorField::operator==(Foam::scalarField&)’
/tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/0/U.boundaryField.inlet:31:19: note: candidates are:
In file included from /home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.H:588:0,
                 from /home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:58,
                 from /home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fixedValueFvPatchFields.H:29,
                 from fixedValueFvPatchFieldTemplate.H:38,
                 from fixedValueFvPatchFieldTemplate.C:26:
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:558:6: note: void Foam::fvPatchField<Type>::operator==(const Foam::fvPatchField<Type>&) [with Type = Foam::Vector<double>]
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:558:6: note:   no known conversion for argument 1 from ‘Foam::scalarField {aka Foam::Field<double>}’ to ‘const Foam::fvPatchField<Foam::Vector<double> >&’
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:568:6: note: void Foam::fvPatchField<Type>::operator==(const Foam::Field<Type>&) [with Type = Foam::Vector<double>]
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:568:6: note:   no known conversion for argument 1 from ‘Foam::scalarField {aka Foam::Field<double>}’ to ‘const Foam::Field<Foam::Vector<double> >&’
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:578:6: note: void Foam::fvPatchField<Type>::operator==(const Type&) [with Type = Foam::Vector<double>]
/home/jw969/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:578:6: note:   no known conversion for argument 1 from ‘Foam::scalarField {aka Foam::Field<double>}’ to ‘const Foam::Vector<double>&’
make: *** [Make/linux64Gcc48DPOpt/fixedValueFvPatchFieldTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/inletBC/platforms/linux64Gcc48DPOpt/lib/libinletBC_a19a66754309cd299efbab21ef5acdb0b4c99e71.so"
file: /tmp/jhwang/1_cylinder_v10_D0.01_timeVaryBC/0/U.boundaryField.inlet from line 19 to line 23.
    From function codedBase::createLibrary(..)
    in file db/dynamicLibrary/codedBase/codedBase.C at line 213.
Does this technique work in OF 2.3? Any idea on the problem? Thanks for any advise.
JHW
f0208secretx is offline   Reply With Quote
Old   June 6, 2014, 22:01
I think your problem is at var*10+10
You are trying to add one double to a field. I would try generating a scalarField of the same size as var where every element is 10 then adding it to var. If you're not sure how to initialize a new scalarField you can just always just make one by copying var again like scalarField var2 = var; then do int num = var2.size() and loop over the elements of var2 making each one of them 10. I'm fairly certain this is not the best way to do this but it will work.
Old   June 7, 2014, 00:52
J.-H. Wang
I simply tried to remove the +10 part but it still doesn't work. Thanks for the answer but its probably not the problem.
JHW
Old   June 7, 2014, 01:05
I re-read your post and if I understand correctly this is a velocity boundary condition so operator needs to be set equal to a 3 component vectorField rather than a scalarField.
f0208secretx likes this.
Old   June 7, 2014, 09:58
J.-H. Wang
Hi ajnewman,
Thanks a lot for the reply. I think that is very much the problem.
Can you be so kind and point me to some documentation I can read in order to understand how to write a velocity boundary condition to a patch? Or where is the class vectorField defined? I am new to OpenFOAM and rusty on C++. Thanks
Sincerely,
JHW
Old   June 7, 2014, 11:37
Assuming that the x_3 component is the one you wish to specify do something like
operator == (vector(0,0,1)*10 + vector(0,0,10));
You may also want to look at
http://www.cfd-online.com/Forums/ope...onditions.html
non-uniform bc
How to set uniform heating boundary condition? Sargam05 OpenFOAM 0 September 11, 2012 10:09
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 22:55
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
