March 19, 2013, 14:15 |
Sutherland transport Coefficients
Efstratios Mavrogiannis
Does anyone know the sutherland transport coefficients (As and Ts) needed in thermophysicalProperties for O2 and H2? Thank you Stratos |
May 17, 2013, 04:28 |
Hi Stratos,
I don't know if you solved your problem, but I use the coefficent, which I found in the combustion/firefoam/les/smallfire3D tutorial. They are in the file "thermo.compressibleGas" and they seem to be the same for all types of gas: transport { As 1.67212e-06; Ts 170.672; } Does anybody know, if they really are the same for all gases? |
March 22, 2017, 09:55 |
Chris Cloney
Rep Power: 9 |
Just an update on this. These coefficients are for nitrogen gas alone and in all of the tutorials are applied to all species (making viscosity and thermal conductivity independent of composition). This may or may not provide sensible enough results depending on the accuracy you are looking for.
Also a note on using multiple coefficients for different species. OpenFoam does some strange mixture rules (not mol or mass based). See more information in the thread here: Mixture viscosity behaving strangely |
Calculate aerodynamic coefficients with openfoam using only opensource programs | Xwang | OpenFOAM | 20 | May 20, 2016 11:26 |
A way to optimize the WENO scheme by optimizing the coefficients of linear scheme | moon_light | Main CFD Forum | 1 | November 27, 2012 09:19 |
Blottner Coefficients | f_sizer | Main CFD Forum | 0 | August 26, 2010 07:03 |
Computing aerodynamic coefficients on bidimensional sections in 3D problems | Aragon | FLUENT | 0 | July 22, 2009 04:07 |
closure coefficients in 2-eq. turb. models | Michael | Main CFD Forum | 2 | December 8, 2003 12:15 |
