How interFoam tell which phase is wetting or non-wetting ?
Old   October 13, 2014, 04:22
Default How interFoam tell which phase is wetting or non-wetting ?
red.yxg is on a distinguished road
Dear all:
Maybe a stupid question.
In interFoam for a given geometry, when we set a case, we give two fluid properties and surface tension in transportProperties, but how interFoam know which fluid is wetting phase and which one is non-wetting phase? When I put surface tension as negative value, time step becomes much shorter and it runs quite slow.
Thanks.
red.yxg is offline   Reply With Quote
Old   October 13, 2014, 05:03
I found it .It is the contact angle that determine which is wetting or non-wetting.
interfoam, surface tension
InterFoam: Add an equation to only one phase voingiappone OpenFOAM Programming & Development 41 June 7, 2022 09:04
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
How interFoam tell which fluid is wetting or non-wetting ? red.yxg OpenFOAM Running, Solving & CFD 0 October 10, 2014 09:45
interfoam: a problem with removing convection in the air phase bieshuxuhe OpenFOAM 0 March 31, 2014 22:56
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
