k-epsilon or k-omega or other models which is more appropriate for internal flow?
Like Tree1Likes
  • 1 Post By jola
Old   May 17, 2013, 00:57
Default k-epsilon or k-omega or other models which is more appropriate for internal flow?
immortality's Avatar
Ehsan
immortality is on a distinguished road
in an internal flow with walls,inlet and outlet which model is more suitable for including both free stream outside of the boundary layer and also near the wall in the boundary layer so that can capture near wall phenomena the best?
Suggestions are appreciated.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 17, 2013, 02:49
Administrator
jola's Avatar
Jonas Larsson
jola is on a distinguished road
Send a message via MSN to jola Send a message via Skype™ to jola
Experts disagree. There is no clear concensus on this. We use SST k-omega for some applications, where secondary flows are strong and a model that is extra conservative for separation predictions is needed. For other applications we user a realizable k-epsilon model, which is easier to work with, converges better and is most often also conservative for separation (not always though)
immortality likes this.
jola is offline   Reply With Quote
Old   May 17, 2013, 07:10
Ehsan
thank you Mr.Larsson
1)If i want to use realizable k-epsilon model how should i treat in the mesh?
I have regions of separation.should i fine the mesh til y+<1 or its sufficinet to be bigger and arround 30?
2)does realizable k-epsilon has an automatic function like kOmegaSST into itself that change to wall function near the wall when 30<y+<60?
Thank you so much.
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Standard K Epsilon and Transitional SST models Robin FLUENT 1 January 17, 2010 18:06
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
justification of the form models of Omega dali Main CFD Forum 0 March 25, 2005 04:11
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
