timeVaryingMappedFixedValue BC
Old   September 27, 2013, 14:20
Default timeVaryingMappedFixedValue BC
Marcelo
marcelorl is on a distinguished road
I trying to simulating a simple geometry in 2D, and my boundary conditions are defined pressure in the inlet and outlet and velocity evaluated by this pressure difference. My problem is that I have to grow the difference of pressure very slow, because if I put a big difference of pressure with a initial field of velocity defined as zero, it does not converge. So, what I am doing is to set a small difference of pressure and as the flow is solved I am changing the difference of pressure. Anyway, what I am trying to do to avoid this work setting a "ramp" in the difference of pressure, using the BC timeVaryingMappedFixedValue.
The problem is that it is not working. I will put my BC here and I appreciate if you can help me on that!
So, my inlet and outlet files are:
for velocity:
inlet
type pressureInletVelocity;
value uniform (0 0 0);
outlet
type zeroGradient;
for pressure:
inlet
type timeVaryingMappedFixedValue;
fileName "ramp.dat";
outOfBounds clamp;
outlet
type fixedValue;
value uniform 0;
My ramp file:
(0.0, 0.001)
(0.1, 0.010)
(1.0, 0.100)
The error message is:
-> FOAM FATAL IO ERROR:
keyword setAverage is undefined in dictionary "/home/marcelo/Desktop/opt/openfoam221/tutorials/incompressible/icoFoam/Projeto/bockmesh/APISeal2D52/0/p.boundaryField.inlet"
file: /home/marcelo/Desktop/opt/openfoam221/tutorials/incompressible/icoFoam/Projeto/bockmesh/APISeal2D52/0/p.boundaryField.inlet from line 25 to line 27.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 402.
FOAM exiting
Thank you very much,
Regards,
Marcelo
marcelorl is offline   Reply With Quote
Old   September 28, 2013, 08:50
Default Tutorial/material
Marcelo
Do you have any material/tutorial reference about this boundary condition?
Thank you very much
Regards
Marcelo
Old   October 4, 2013, 13:11
Jace
zhengzh5 is on a distinguished road
Thank you very much
Regards
Marcelo
i think you're looking for timeVaryingUniformFixedValue boundary condition and not the timeVaryingMappedFixedValue. And I don't have any reference on hand, there should be some lying around the forum if you do some digging.
zhengzh5 is offline   Reply With Quote
Old   January 2, 2014, 01:17
vishal
vishal_s is on a distinguished road
Hi Marcelo, I am also facing the same problem. I tried out both timeVaryingMappedFixedValue and timeVaryingUniformFixedvalue but did not worked. Did you figured out how to solve the problem?
vishal_s is offline   Reply With Quote
Old   January 2, 2014, 04:50
Antimony is on a distinguished road
Hi Marcelo,
Have you looked at the pitzDailyExptInlet under simpleFoam? Based on the error message that you have, it seems like you have missed out defining the "setAverage" value in the file indicated in the error. Perhaps the tutorial might help you with it?
Regards,
Antimony
Antimony is offline   Reply With Quote
