Inlet and Outlet BC for maximum flow of a radial fan
Like Tree1Likes
  • 1 Post By nash
Old   October 24, 2013, 03:44
Default Inlet and Outlet BC for maximum flow of a radial fan
nash is on a distinguished road
Hi everyone,
I'm now doing simulation on radial fan to reproduce the fan performance curve. Now I'm stuck in the case for maximum flow rate of the fan.
My boundary conditions that I would like would be pressures on inlet and outlet, and the mass flow rate/volumetric flow rate will be extracted from the simulation.
The static pressure in the room may be at atmosphere, but the dynamic pressure is nearly zero and therefore the total pressure is equal to static pressure. This is not the case at the inlet of the fan. At the inlet, the static pressure will decrease as the mass flow rate increases, with the total pressure remaining nearly constant.
so i think i would like to use static pressure in outlet and total pressure in inlet.
But what value should i set to my p0 and value in totalpressure BC, while i set the static pressure outlet to zero.
or should i use other BCs?
thanks for the help
-nash-
hussam893 likes this.
nash is offline   Reply With Quote
boundary condition, fan, radial, simplefoam
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
inlet has higher pressure than outlet in axial flow fan sivakumar Main CFD Forum 37 July 21, 2014 08:34
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
