inconsistent number of faces between block pair A & B for a quarter of pipe
Old   November 15, 2013, 11:13
Default inconsistent number of faces between block pair A & B for a quarter of pipe
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Hi everyone
I want to model a quarter of pipe by using blockMeshDict.
the dimension of pipe is 0.3meter length and 0.003meter radius.
I want to generate full structured mesh so I've created 3 blocks.
the blockMeshDict is exactly like below:
convertToMeters 1;
vertices
    (0 0 0)      //0
    (0 0 0.001)
    (0 0.001 0.001)      //2
    (0 0.001 0)
    (0 0 0.003)   //4
    (0 0.0021213 0.0021213)
    (0 0.003 0 )      //6
    (0.3 0 0)      //7
    (0.3 0 0.001)
    (0.3 0.001 0.001)      //9
    (0.3 0.001 0)
    (0.3 0 0.003)   //11
    (0.3 0.0021213 0.0021213)
    (0.3 0.003 0 )      //13
blocks
    hex (7 8 9 10 0 1 2 3) (300 10 10) simpleGrading (1 1 1)
    hex (8 11 12 9 1 4 5 2) (300 10 50) simpleGrading (1 1 1)
    hex (10 9 12 13 3 2 5 6) (300 50 10) simpleGrading (1 1 1)
edges
    arc 4 5 (0 0.001148 0.00277)
    arc 5 6 (0 0.00277 0.001148)
    arc 11 12 (0.3 0.001148 0.00277)
    arc 12 13 (0.3 0.00277 0.001148)
boundary
    inlet
        type patch;
        faces
            (0 1 2 3)
            (1 4 5 2)
            (2 5 6 3)
    outlet
        type patch;
        faces
            (7 10 9 8)
            (8 9 12 11)
            (9 10 13 12)
    side1
        type cyclic;
        neighbourPatch side2;
        faces
            (0 7 8 1)
            (1 8 11 4)
    side2
        type cyclic;
        neighbourPatch side1;
        faces
            (0 3 10 7)
            (3 6 13 10)
    walls
        type wall;
        faces
            (4 11 12 5)
           (5 12 13 6)
but when I execute blockMesh in terminal, the following fatal Error appears;
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 1
    From function blockMesh::calcMergeInfo()
    in file blockMesh/blockMeshMerge.C at line 221.
FOAM exiting
i know it is about number of cells for patches between the blocks but I have not been able to make it correct .
can anybody help?
thanks.
Arjang
AmirBaqa1987 is offline   Reply With Quote
Old   November 15, 2013, 12:00
Nima Samkhaniani
nimasam is on a distinguished road
it should be like this:
blocks
hex (7 8 9 10 0 1 2 3) (10 10 300) simpleGrading (1 1 1)
hex (8 11 12 9 1 4 5 2) (10 10 300) simpleGrading (1 1 1)
hex (10 9 12 13 3 2 5 6) (10 10 300) simpleGrading (1 1 1)
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 15, 2013, 12:21
Arjang Behnoud
Thanks Dear Nima
I want to set the following simpleGrading:
hex (8 11 12 9 1 4 5 2) (50 10 300) simpleGrading (0.1 1 1)
hex (10 9 12 13 3 2 5 6) (10 50 300) simpleGrading (1 0.1 1)
but terminal says :
face 3001 area does not match neighbour by 1.41456% -- possible face ordering problem.
patch:side1 my area:5.54069e-08 neighbour area:5.46286e-08 matching tolerance:0.0001
Mesh face:973101 fc:(0.2985 0 0.0010277)
Neighbour fc:(0.2995 0.00108272 0)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.
where can I increase the 'matchTolerance' ?
Old   November 16, 2013, 05:15
Nima Samkhaniani
but im afraid that it solves your problem
type cyclic;
faces
(0 7 8 1)
(1 8 11 4)
matchTolerance 0.01;
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[blockMesh] Error in BlockMesh: inconsistent number of faces pc1 OpenFOAM Meshing & Mesh Conversion 7 August 20, 2010 06:24
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
