Change P-rgh to Pfor interFoam
Old   December 1, 2013, 22:41
Default Change P-rgh to Pfor interFoam
vishal
vishal_s is on a distinguished road
I am working on a multiphase flow. I have P value but in interfoam P_rgh is given. How to change P-rgh to P in the solver???
vishal_s is offline   Reply With Quote
Old   December 2, 2013, 06:50
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
in your solver both variables exists.
Can you describe your Problem in a other way?
Do you want to set up "p" instead of "p_rgh"?
p_rgh = p - rho*gh;
p = p_rgh + rho*gh;
    volScalarField p
        IOobject
            "p",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        p_rgh + rho*gh
Tobi is offline   Reply With Quote
Old   December 2, 2013, 06:55
vishal
Tobi, I am working on an external nozzle flow problem. In this case, the inlet pressure to the nozzle is know to me and the outlet is atmosphere.
Now in interFoam, we have p_rgh instead of P. Now If I am not wrong, P_rgh is the local dynamic pressure. SO how to set P in this case. If my inlet P is 4e6 what will be my p_rgh???
Old   December 2, 2013, 22:51
vishal
yes Tobi, I want to set P. Can you tell me how to do it????
Old   December 3, 2013, 06:16
Tobi's Avatar
Tobias Holzmann
As you can see in the code above the p-file is not read while starting the solver but will be automatically generated every time step you save.
For your Problem the easiest way would be the following:
- calculate p_rgh at the inlet and set it to fixedValue so that you reach p
As shown you can do this with:
p_rgh = p - rho * gh
1. you know p
2. you know rho
3. you know g
4. you should know h
Thermal phase change model Piti CFX 1 January 14, 2021 10:03
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
How to change contour line thickness? Mishar Siemens 0 December 15, 2004 10:28
How to change the reference pressure value to 0 Pa Lee Siemens 2 July 1, 2003 00:32
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
