perforated plate boundary - Air injector bubble column
Like Tree1Likes
  • 1 Post By Jonas Ansoni
Old   June 9, 2014, 16:00
Default perforated plate boundary - Air injector bubble column
Jonas L. Ansoni
Jonas Ansoni is on a distinguished road
Hello everybody,
I've done simulations of reactor (figure. bellow) using interDyMFoam. In these simulations I inserted the 11 air injectors (injector area 4mm^2) direct in the blockMeshDict.
So searching I found the following material perforatedPlateBoudary. I tested the first alternative of the tutorial, but didn't work. I'm checking if is some version problem (I'm working with OF2.0.1).
Is there any easier way to insert the air injectors?
Another problem is with the size of the injectors, for small sizes (< 3mm^2) the simulation does not converge.
Any suggestion is strongly appreciated.
Thanks.
mwaqas likes this.
Jonas Ansoni is offline   Reply With Quote
Old   August 16, 2014, 15:42
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello Jonas Ansoni
Have you solved your problem for perforated boundary condition ??
I am simulating fluidized bed and I want apply perforated base too. If you are succeeded, please share your experience. Thank you.
mwaqas is offline   Reply With Quote
Old   August 23, 2014, 10:29
Jonas L. Ansoni
Hi!
Sorry for the delay.
I used square holes as injectors for very small holes.
Regarding the tutorial (perforatedPlateBoundary) I didn't get success.
kind regards
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
boundary condition for flat plate Ardalan Main CFD Forum 0 June 18, 2010 17:49
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
