changeDictionaryDict, adjust BC in processorX folders?
Old   December 2, 2013, 07:22
Default changeDictionaryDict, adjust BC in processorX folders?
phil
gelbebanane is on a distinguished road
Hi there,
i struggle to adjuste my BC.
As in the snappyHexMeshDict file it is written, I cannot define my patches inside it as cyclic, mapped etc.
I found a way to edit it with the changeDictionaryDict. The only problem is, when i create my snappy mesh decomposed in parallel, the changeDictionaryDict command does not change the BC inside the processorX/0 folders as well. And when i edit the BC in /0 before decomposing i get errors about non existing patches!
So my question is:
I really dont want to edit the whole files manually. Is there any other way to change the BC in a decomposed case after running snappyHexMesh or is there even a possibility to define my BC as cyclic mapped etc inside the snappyHexMeshDict
(you can find a changeDictionaryDict File in the tutorial /heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/bottomAir/changeDictionaryDict)
Greetings
gelbebanane is offline   Reply With Quote
Old   February 10, 2014, 02:46
phil
Ok so i will answer the question for myself.
First of all i wanted to use mapped BC but thats not anymore neccessary for me so i use createPatch to edit my BC file.
But for other users i will still answer my question.
First of all run snappy with "snappyHexMesh -overwrite" in parallel. Afterwards you have to "reconstructParMesh -constant" the mesh and then you can delete the processor* folders.
Now we use "changeDictionary" and everything works now.
After we changed our boundary file, we now can decompose the case again with the new boundary file.
Greetings
p.s. you can find an example file of changeDictionaryDict in the applications/utilities... folders of your OF installation.
Old   February 10, 2014, 05:53
Olivier
olivierG is on a distinguished road
hello,
In parallel juste use the "-parallel" option of changeDictionary, just as most OF tools work with // cases.
( so the commande line will be "mpirun -np X changeDictionary -parallel")
regards,
olivier
olivierG is offline   Reply With Quote
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
how to put time folders in a unique folder immortality OpenFOAM Post-Processing 9 August 14, 2013 05:03
preventing of writing of excess folders immortality OpenFOAM Post-Processing 3 July 29, 2013 10:56
Strategy for keeping track of files and folders? Dre CFX 1 October 30, 2008 13:00
Help with ADJUST FUNCTION Munir Ahmed Khan FLUENT 0 August 8, 2008 06:33
