scotch decomposition is crashing my mesh
Old   May 5, 2014, 17:30
Default scotch decomposition is crashing my mesh
robo
robo is on a distinguished road
I'm working on an external flow that I'm running in simpleFoam at the moment trying to get a steady state solution. The mesh is around 2 million cells; developed using snappyHexMesh. It passes all mesh checks, and I've run it in serial for around 100 steps with no problems. When I decompose it using scotch decomposition in decomposePar, if I use more then 2 processors, it will crash on the first step, claiming that the U matrix is singular. If I use a simple decomposition, it runs fine.
I would like to be using more processors then I can easily develop a simple decomposition for, however clearly something is wrong with scotch/decomposePar and I am not sure how to debug it. Has anyone run into similar issues? Any advice on using the scotch decomposition? Is metis more reliable? I'm using OF 2.3.0 if that's relevant.
robo is offline   Reply With Quote
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
OpenFOAM Scotch Decomposition: Version and Reference dancfd OpenFOAM Pre-Processing 4 April 16, 2014 21:40
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 07:00
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
